Введение
In this tutorial, I will show you how to do a complete teardown of this monitor, using only two different sized Philip's head screwdrivers
Выберете то, что вам нужно
Place the monitor on its screen side down
Remove the four screws holding the stand onto the monitor
To remove the backing, remove the two screws holding the case in place.
The monitor is held in place with clips. Lightly bend the backing backwards to separate the frame from the screen
We must first remove the circuits connected to the buttons used to calibrate the monitor
Remove this section by unscrewing the three screws holding it in place
Remember that this section is connected by wires, and should be handled carefully
Hold right below the cables and pull the cable apart from the top circuit board
There are four screws on each side of the monitor that you must remove to disassemble the rest of the monitor
These screws are relatively tiny, so make sure that they are stored securely
Remove the backing of the circuit board by unscrewing the four screws holding it in place
Make sure Step 3 was completed in full because it is connected to this part
Remove these panels after the past steps have been completed in full
Remove the tape covering any of the screws or wires we will remove in future steps
Remove the three screws on the circuit board
Use the mini Philip's head
Remove the two smaller screws on the side circuit board
Remember to use the mini Philip's head
Pop away the metal frame surrounding the LCD monitor
This is similar to removing the other frame in step 2
Raise the green circuit boards up
Holding the screen vertically, slide the black screen off
Remove the plastic filter sheets covering the LCD glass panel
Place your fingers on the sides of the glass panel and lift it upwards to remove it
Place the monitor white side up
Just like the previous frames, pop the plastic black frame apart from the rest of the monitor
gently lift the two metal bars connected to the circuit board.
This will separate the two components apart
You have successfully completed a teardown of the Envision EN7410 monitor
