Выберете то, что вам нужно
Видео обзор
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Essential Phone, воспользуйтесь нашим сервисным руководством.
  1. Essential Phone Teardown, Essential Phone Teardown: шаг 1, изображение 1 из 3 Essential Phone Teardown, Essential Phone Teardown: шаг 1, изображение 2 из 3 Essential Phone Teardown, Essential Phone Teardown: шаг 1, изображение 3 из 3
    • Here are the Essential Phone's essentials:
    • Qualcomm Snapdragon 835 containing a Kryo 280 Octa-core CPU and an Adreno 540 GPU, paired with 4 GB RAM
    • 128 GB UFS 2.1 onboard storage
    • 5.71" LCD with 2560 × 1312 resolution (504 ppi)
    • Dual 13-megapixel rear cameras (one RGB + one monochrome) with image fusion technology
    • Front-facing camera with 8 MP resolution and 16:9 aspect ratio
    • 802.11a/b/g/n/ac Wi‑Fi + MIMO Bluetooth 5.0 LE + NFC
  2. Essential Phone Teardown: шаг 2, изображение 1 из 2 Essential Phone Teardown: шаг 2, изображение 2 из 2
    • In their quest for a bezel-less screen, Essential managed to carve out some space for a front-facing camera and a nigh-invisible slit for the earpiece speaker.
    • Around back, we find this phone's party trick—two power pins with built-in magnetic alignment. This is where the unessentials can latch on to the Essential Phone. While more are promised, as of now a 360° camera is the only accessory available from Essential.
    • Modular smartphone systems have yet to take off, but it's an idea we can appreciate—the environmental toll of clipping on a hot new camera module is a lot lower than upgrading your whole phone because the camera got "old."
    • We also spot a built-in dual camera system for those looking for good ol' ~180° photos, plus the fingerprint sensor responsible for securing the Essential's essentials.
  3. Essential Phone Teardown: шаг 3, изображение 1 из 2 Essential Phone Teardown: шаг 3, изображение 2 из 2
    • Essential deemed a headphone jack unessential, providing just a USB-C connector instead. Risky.
    • Flanking the connector are the speaker grill, SIM card slot, and lower microphone. Just like in the Galaxy S8, the SIM eject and microphone holes seem a little too similar for comfort.
    • ...and it proved to be an issue.
    • Essential left us a little surprise under the SIM card. With a totally blank and unbranded exterior, they hid all the identifying marks inside on a cute little tag.
    • We're amused to find that it doesn't come out all the way. Did Essential assemble the phone around this little tag?
  4. Essential Phone Teardown: шаг 4, изображение 1 из 3 Essential Phone Teardown: шаг 4, изображение 2 из 3 Essential Phone Teardown: шаг 4, изображение 3 из 3
    • It's past time to peek inside, but we're having no luck getting in. With no visible screws, we can only assume it's assembled with glue—but ever-increasing amounts of heat and suction haven't helped weaken this phone's hold on the display.
    • In desperation, we reverse polarity and try some Super Cold.
    • After a harrowing arctic expedition, it's the back cover that finally loosens first, revealing...
    • ...Nothing! Beneath the giant glue pad, we find only the wrong ends of a couple screws and a midframe assembly.
    • We stay frosty, now more determined than ever to peel up the frozen LCD panel while dealing with the fallout from previous prying attempts.
    • Looks like we have a different definition of essential than Essential does—our Essential Electronics Tool Kit, designed to tackle all common electronics repairs, wasn't enough to crack this nut of a phone. Some intense reinforcements were necessary.
    • Even after peeling up the LCD panel, the interior continues to be well-guarded. After all that work, all we have to show for it is a busted display, a blank midframe shield, and a stray IC on the back of the display:
    • Qualcomm QTC800S touchscreen controller (likely)
    • The cover glass separates from the LCD panel rather easily. That could be good if you just wanted to swap out some cracked glass, but the challenging opening procedure makes that prospect somewhat dubious.
  5. Essential Phone Teardown: шаг 6, изображение 1 из 3 Essential Phone Teardown: шаг 6, изображение 2 из 3 Essential Phone Teardown: шаг 6, изображение 3 из 3
    • After the unexpectedly difficult journey through the outside of the phone, we lift the midframe shield to finally reveal some internal components.
    • We spy: a heat pipe, a bunch of grounding fingers, and a battery with stretch-release adhesive ... that's trapped under another bracket.
    • Credit where credit is due: stretch-release adhesive is the most repair-friendly adhesive, and we wish more manufacturers would adopt it. Unfortunately it's kind of wasted on a phone that's this hard to get into.
    • The battery claims an 11.70 Wh capacity—not too shabby when compared with the Galaxy S8 at 11.55 Wh, the iPhone 7 at 7.45 Wh, or the OnePlus5 at 12.35 Wh.
  6. Essential Phone Teardown: шаг 7, изображение 1 из 3 Essential Phone Teardown: шаг 7, изображение 2 из 3 Essential Phone Teardown: шаг 7, изображение 3 из 3
    • That little mattress tag we found in the SIM slot removes quite easily from this side. It does indeed look like the phone was assembled with this little guy comfortably in place.
    • Meanwhile, we remove the massive motherboard, including its peninsular (Floridian?) charging port protuberance. The USB-C port is soldered straight to the motherboard. We are disappointed.
    • If you need to replace this high-wear component, you're in for an (expensive) microsoldering job or a (very expensive) full-motherboard replacement.
    • Speaking of removing the board...
    • The backside of the motherboard is snaked with antenna interconnect cables and vacant coaxial connectors.
  7. Essential Phone Teardown: шаг 8, изображение 1 из 1
  8. Essential Phone Teardown: шаг 9, изображение 1 из 1
    • And for the backside:
    • Qorvo QM78012 RF fusion LB module
    • Skyworks Solutions 77360-2 power amplifier module
    • Avago AFEM-9046 and AFEM-9036 IC's
    • Qualcomm PM8998 (similar to PM8920)
    • NXP Semiconductors TFA9891 audio amplifier
    • Qualcomm SMB1381 power management IC
    • ON Semiconductor DC-DC converter (likely)
  9. Essential Phone Teardown: шаг 10, изображение 1 из 2 Essential Phone Teardown: шаг 10, изображение 2 из 2
    • And the rest of the chips:
    • Qualcomm PM8005 power management IC
    • SiBeam SB6212CZU Snap wireless connector IC
    • Fresco Logic FL1100-1A0-LX USB 3.0 host controller
    • Qualcomm QET4100 envelope tracker
    • Texas Instruments TPS61235P 8 A synchronous boost converters
    • NXP Semiconductor Q2101 NFC controller (likely)
    • ON Semiconductor FSUSB43L10X 480 Mbps, USB 2.0 DPDT switch
  10. Essential Phone Teardown: шаг 11, изображение 1 из 2 Essential Phone Teardown: шаг 11, изображение 2 из 2
    • Sensor Identification:
    • STMicroelectronics VL53L0X time-of-flight/gesture sensor
    • STMicroelectronics LSM6DSM 3-axis accelerometer/gyroscope
    • AKM Semiconductor AK09915C 3-axis accelerometer
    • Bosch Sensortec BMP285 pressure sensor (likely)
    • Rohm hall sensor
  11. Essential Phone Teardown: шаг 12, изображение 1 из 3 Essential Phone Teardown: шаг 12, изображение 2 из 3 Essential Phone Teardown: шаг 12, изображение 3 из 3
    • With the motherboard on ice, we're finally able to tweeze out the dual camera module.
    • Either Essential accidentally put these camera pop connectors on backwards, or someone had too much fun figuring how to origami them into place.
    • Nearby, the selfie cam lies on a strip of glue and takes a little more work to extract, bringing the front-facing sensor cable along for the ride.
    • Surprise! The front-facing camera and earpiece speaker come as a single part. That tiny port lines up directly with the über-slim grille at the top of the phone!
    • The small flex cable terminates with possibly an AMS TMD3700 color sensor.
  12. Essential Phone Teardown: шаг 13, изображение 1 из 3 Essential Phone Teardown: шаг 13, изображение 2 из 3 Essential Phone Teardown: шаг 13, изображение 3 из 3
    • De-capping (literally, it looks like a cap) the vibrator, we're surprised there's no rubber dampener between these pieces.
    • The vibrator appears to be a standard pancake style cell motor, albeit a little taller than the usual short-stack.
    • Among the final components out: the sprawling loudspeaker and accompanying contact cable.
    • With its odd shape, the speaker kinda looks like it was designed to fill all unclaimed real estate in the phone body.
  13. Essential Phone Teardown: шаг 14, изображение 1 из 3 Essential Phone Teardown: шаг 14, изображение 2 из 3 Essential Phone Teardown: шаг 14, изображение 3 из 3
    • Magnets for those modular clip-on accessories are neatly labeled. They'd be tough to replace, but that's okay—you're likely to be rocking a different phone by the time they start to wear out in 700 years or so.
    • Not much remains besides the fingerprint sensor, glued comfortably in place on the back—a location that comes with some drawbacks, but is quickly becoming the de facto smartphone standard. Well, sort of.
    • The fingerprint sensor is likely a FPC1020, while the fingerprint controller may be a FPC2050.
  14. Essential Phone Teardown: шаг 15, изображение 1 из 1
    • For promising just the essentials, the Essential Phone took a lot more out of us than expected. It also took a lot more Super Cold than expected...
    • Enjoy this layout shot while we grab the winter coats from our closet and defrost the teardown room.
  15. Заключительные мысли
    • To the extent that screws are used, they are all standard Phillips/JIS fasteners.
    • The battery is secured with repair-friendly stretch-release adhesive. Too bad it's so inaccessible.
    • The USB-C port is soldered to the motherboard, and with no headphone jack it'll be subject to extra wear.
    • Nearly invisible seams and copious adhesive means any attempt at repair is likely to inflict as much damage as it fixes.
    • Did we mention we had to freeze it?
    Уровень ремонтопригодности
    Ремонтопригодность 1из 10
    (10 легче всего ремонтировать)
Scott Havard
Участник с: 06/27/16
49 326 Репутация
Автор 31 руководств
64 Комментариев
wow horrific phone! 10/10 to iFixit for effort, 0/10 to Essential!
Will - Ответить
This is a phone where iFixit will have to determine if it's even worth selling replacement parts.
iPostIt - Ответить
the repair score should imo get a zero instead of a 1 because you cant open the %#*@ thing without destroying it.
My1 - Ответить
this phone is essentially future trash. too bad
thanks iFixit for the honest repair score!
Andrew - Ответить
Why a phone is bad because independent repairs are almost impossible?
OEM has been moving to proprietary components and outta-nowhere configuration to have on purpose to un-motivate people to go to beyond the warranty and authorized repair centers, since YEARS ago.
I appreciate the work from iFixit but saying that you won't buy a phone or it is "DOA" because OEM wants to control THEIR products is so childish at theses modern days.
(Please, spare me the "is easy for you to say because you don't own or work on a workshop and repairs give food to our tables". I know a few owners that although s just more spending, they are working on becoming authorized repair center for most brands.)
TheGeeZus - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 38
За последние 30 дней: 161
За всё время: 197,266
