ΠΠ²Π΅Π΄Π΅Π½ΠΈΠ΅
This is a complete teardown of Fitbit surge, let's see what makes this "Ultimate Fitness Super Watch" tick.
ΠΡΠ±Π΅ΡΠ΅ΡΠ΅ ΡΠΎ, ΡΡΠΎ Π²Π°ΠΌ Π½ΡΠΆΠ½ΠΎ
Fitbit's latest fitness "super watch" has some pretty nice features, including:
Built-in GPS
Wrist-based optical heart rate monitor
Wireless syncing to smartphone or computer
7+days of battery life without gps and up to 7h with gps (according to some reviews)
Remove the four screws
The bands are glued pretty well so you need to cut your way through to remove them and expose the fibit body
Cutting through the middle and lifting sideways worked pretty well
Once you remove the bands scrape away the glue on the top side to expose the GPS antenna
On the other band you'll find the bluetooth antenna which is actually a flexible antenna glued to the inside of the band.
This antenna can be left on the surge if you try to detach wrist band by fitting something thin between front glass and the band.
With the bands out of the way it's time to go inside Fitbit's guts
Remove the four metal parts as shown in the photo
After that just insert a screw driver or other sharp object into the fissure and voilΓ‘
Right after splitting Fitbit into 2 the first component is immediately exposed
Cypress CY8CTMA463 touchscreen controller
After removing the large shield on the main PCB the brains of the gadget become visible
Silicon Labs EFM32 Giant Gecko (ARM Cortex-M3) EFM32GG395F1024
Micron Serial NOR Flash N25Q064A11ESEA0F
(Cypress touchscreen controller still visible here plugged into the main PCB)
After removing the battery holder the main PCB can be carefully dislodged from the plastic body
Texas Instruments Battery Charger BQ24232H
MediaTek GPS Receiver MT3339 (couldn't find any datasheet, just a press release on it)
Texas Instruments Bluetooth Controller CC2564
The LCD is secured with 3 very visible screws on the bottom side
Sharp TFT-LCD LS013B7DH01
52 ΠΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΠ΅Π²
Any idea about the sensors? The heart rate sensor is obvious, and I'm sure there are accelerators. I think the white topped part near the TI battery charger is an altimeter. Anything else on there that anyone recognizes?
Hi Chris,
Yes it's a MS5805-02BA01 pressure sensor.
I've been trying to repair a Fitbit charge and the device had a dry joint. Sadly I was unable to repair it. Bin job :(
Could you show photos of the area where the Heart Rate Sensor is located. It is Seen clearly in Step5 - first picture. Is it a custom sensor or does it use a 3rd party sensor
Is it possible to replace the glass that goes over the screen?
@Tim: yes, I would like to know the same thing? Is it possible to replace a cracked screen and if so, how much is the part?
