Введение
Needed to get this monitor open to do some tinkering.
1 - Remove the three screws on the back
2 - Slip iFixit Opening Pick between the back and front.
3 - use an iFixit Opening Tool to pry the halves apart. Work your way slowly around moving the pick until it stops and then prying with the Opening Tool.
There are 3 connections and 6 screws that need to be removed.
The top connection needs to removed before you can pull off the white tape. Squeeze the tabs in and pull down.
Pry up the clip locks up before pulling out.
Remove the 2 screws and pry the sheet metal past the black tabs to separate the LDC module.
