Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Инструменты для этого Разбора
Введение
Facts about floppy disks
  • The casings are hard
  • The disks are floppy
  • Once opened, they don't go back together
  • They're old.
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Floppy Disk, воспользуйтесь нашим сервисным руководством.
  1. The floppy disk has gone the way of the dinosaur. Except for Google's lovable jumping dinosaur.
    • The floppy disk has gone the way of the dinosaur.
    • Except for Google's lovable jumping dinosaur.
    • These disks might hold one or two photos at best; they probably won't hold much more though at only 2MB.
    • It's worth noting that today's photos taken can be upwards of 10MB on their own!
    • We liked skimmilk05's teardown so much (and his amazing attempt at his own teardown graphic) we supplied one of our own for this truly unique community contributed teardown. - iFixit Staff <3
    • Thin metal pieces are good places to start.
    • This one's so thin that you can bend it with a finger.
    • This one wasn't too hard, but if you're having trouble getting it up, a Jimmy comes in handy.
  2. With some careful prying, the entire lid pops right off. You may need a spudger, metal spudger, Jimmy, or a combination of the three to get into the crack where the metal piece once was. There are little pushpins holding the two halves together, but they were pulled apart during disassembly, easy as 1, 2, 3!
    • With some careful prying, the entire lid pops right off.
    • You may need a spudger, metal spudger, Jimmy, or a combination of the three to get into the crack where the metal piece once was.
    • There are little pushpins holding the two halves together, but they were pulled apart during disassembly, easy as 1, 2, 3!
    • And we get a glimpse of what's inside! Spoiler alert: not much is there.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. In cracking open the casing, we lost a tiny little spring.
    • In cracking open the casing, we lost a tiny little spring.
    • Boing.
    • Boing.
    • Playtime's over. Best guess as to what it is? Keeping that metal piece over the tape inside.
  5. On the inside, we see a small pad, probably to clean the turning disk that's inside.
    • On the inside, we see a small pad, probably to clean the turning disk that's inside.
    • This one was pretty nasty. Eww.
    • This pad is glued into the casing with some tough adhesive; the manufacturer really didn't want this pad coming out on its own.
    • Aha!
    • The meat n' bones of the floppy disk, the disk itself!
    • Ever wondered why the floppy disk was called the "floppy" disk, even though it was in that hard plastic case? This is why.
  6. More floppy goodness. More floppy goodness.
    • More floppy goodness.
  7. It's a pretty simple device in all. Not much else to say here.
    • It's a pretty simple device in all. Not much else to say here.
  8. Floppy Disk Repairability Score: 1 out of 10 (10 is the easiest to repair) This antique technology has virtually no replacement parts.
    • Floppy Disk Repairability Score: 1 out of 10 (10 is the easiest to repair)
    • This antique technology has virtually no replacement parts.
    • Replacement of the tape or cleaning pads are impossible without breaking the case.
    • The cleaning pads are held on with tight adhesive, making replacement difficult.
    • Attempts to use heat to loosen adhesive may result in the case melting.
    • High susceptibility to magnets make this device very sensitive.
Seji the veggie
Участник с: 09.02.2015
1 890 Репутация
1 руководство автора
Комментариев: 10
Super cool! Haven't seen a floppy disk in forever.
Taylor Whitney - Ответить
They are a tad old...haha
Seji the veggie -
This is amazeballs. Solid work!
Kay-Kay Clapp - Ответить
"floppy goodness" -- so good
Julia - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 17
За последние 30 дней: 142
За всё время: 7,098
