Выберете то, что вам нужно
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Floppy Disk, воспользуйтесь нашим сервисным руководством.
  1. Floppy Disk Teardown, Floppy Disk Teardown: шаг 1, изображение 1 из 2 Floppy Disk Teardown, Floppy Disk Teardown: шаг 1, изображение 2 из 2
    • The floppy disk has gone the way of the dinosaur.
    • Except for Google's lovable jumping dinosaur.
    • These disks might hold one or two photos at best; they probably won't hold much more though at only 2MB.
    • It's worth noting that today's photos taken can be upwards of 10MB on their own!
    • We liked skimmilk05's teardown so much (and his amazing attempt at his own teardown graphic) we supplied one of our own for this truly unique community contributed teardown. - iFixit Staff <3
  2. Floppy Disk Teardown, Removing the Cover: шаг 2, изображение 1 из 2 Floppy Disk Teardown, Removing the Cover: шаг 2, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Jimmy
    $7.95
    Купить
    • Thin metal pieces are good places to start.
    • This one's so thin that you can bend it with a finger.
    • This one wasn't too hard, but if you're having trouble getting it up, a Jimmy comes in handy.
  3. Floppy Disk Teardown, Removing the Casing: шаг 3, изображение 1 из 3 Floppy Disk Teardown, Removing the Casing: шаг 3, изображение 2 из 3 Floppy Disk Teardown, Removing the Casing: шаг 3, изображение 3 из 3
    • With some careful prying, the entire lid pops right off.
    • You may need a spudger, metal spudger, Jimmy, or a combination of the three to get into the crack where the metal piece once was.
    • There are little pushpins holding the two halves together, but they were pulled apart during disassembly, easy as 1, 2, 3!
    • And we get a glimpse of what's inside! Spoiler alert: not much is there.
  4. Floppy Disk Teardown, The Spring: шаг 4, изображение 1 из 1
    • In cracking open the casing, we lost a tiny little spring.
    • Boing.
    • Boing.
    • Playtime's over. Best guess as to what it is? Keeping that metal piece over the tape inside.
  5. Floppy Disk Teardown, The Cleaning Pad: шаг 5, изображение 1 из 1
    • On the inside, we see a small pad, probably to clean the turning disk that's inside.
    • This one was pretty nasty. Eww.
    • This pad is glued into the casing with some tough adhesive; the manufacturer really didn't want this pad coming out on its own.
    • Aha!
    • The meat n' bones of the floppy disk, the disk itself!
    • Ever wondered why the floppy disk was called the "floppy" disk, even though it was in that hard plastic case? This is why.
  6. Floppy Disk Teardown, The Disk: шаг 7, изображение 1 из 2 Floppy Disk Teardown, The Disk: шаг 7, изображение 2 из 2
    • More floppy goodness.
    Any ideas how to reattach the centre metal ring due to adhesive going bad
    tanglebeans - Ответить
  7. Floppy Disk Teardown, Wrap-up: шаг 8, изображение 1 из 1
    • It's a pretty simple device in all. Not much else to say here.
  8. Floppy Disk Teardown, Final Thoughts: шаг 9, изображение 1 из 2 Floppy Disk Teardown, Final Thoughts: шаг 9, изображение 2 из 2
    • Floppy Disk Repairability Score: 1 out of 10 (10 is the easiest to repair)
    • This antique technology has virtually no replacement parts.
    • Replacement of the tape or cleaning pads are impossible without breaking the case.
    • The cleaning pads are held on with tight adhesive, making replacement difficult.
    • Attempts to use heat to loosen adhesive may result in the case melting.
    • High susceptibility to magnets make this device very sensitive.
Seji the veggie
Участник с: 02/09/15
1 986 Репутация
1 руководство автора
10 Комментариев
Super cool! Haven't seen a floppy disk in forever.
Taylor Whitney - Ответить
They are a tad old...haha
Seji the veggie -
This is amazeballs. Solid work!
Kay-Kay Clapp - Ответить
"floppy goodness" -- so good
Julia - Ответить
I've found that floppy disks make great coasters! On a serious note, actually got a call from a client last week asking me if I could make a floppy disk for him, as his work computer didn't have a floppy drive. He emailed me the program. Turns out it was for some sort of CNC or milling machine that still uses floppies. Never count out the old school equipment.
Gregory Hostiuck - Ответить
Indeed! Neglect not.
Seji the veggie -
1. You forgot the little plastic tab in the corner that blocks writing if necessary.
2. Repairability 1 out of 10: are you serious? you just never used Scotch tape to tape two halves of the body together. Also, that thing works happily without the metal shutter.
damiracle - Ответить
Come on man, everyone knows that scotch tape doesn't last more than a day. :)
Seji the veggie -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 49
За всё время: 10,500
