Введение
This is a basic teardown of the HTC Rezound showing the various components.
This teardown is not a repair guide. To repair your HTC Rezound, use our service manual.
  1. Remove rear cover using little notch located at bottom of phone Remove rear cover using little notch located at bottom of phone Remove rear cover using little notch located at bottom of phone
    • Remove rear cover using little notch located at bottom of phone
  2. Remove 1620 mAh battery
    • Remove 1620 mAh battery
    • Remove SD card
    • Phone comes with 16 GB SD card
  3. Remove (6) Torx T7 screws You may have to remove VOID sticker from one of the screws
    • Remove (6) Torx T7 screws
    • You may have to remove VOID sticker from one of the screws
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Use opener tool to carefully pry cover off Volume and power buttons are located in cover so be careful not to lose them Speaker is located inside back cover
    • Use opener tool to carefully pry cover off
    • Volume and power buttons are located in cover so be careful not to lose them
    • Speaker is located inside back cover
      • Main Camera
      • Headphone jack
      • Vibration motor
  6. Carefully unplug board Carefully remove camera cover, slowly peeling off tape to reuse Remove and unplug vibration motor
    • Carefully unplug board
    • Carefully remove camera cover, slowly peeling off tape to reuse
    • Remove and unplug vibration motor
  7. Remove (2) Phillips heads screws (one is shown, the other is on the left lower side) Disconnect two cables from logic board to screen. Be very careful not to break our bend too badly. Main camera connection & front camera
    • Remove (2) Phillips heads screws (one is shown, the other is on the left lower side)
    • Disconnect two cables from logic board to screen. Be very careful not to break our bend too badly.
    • Main camera connection & front camera
  8. Using pick or pry tool, slowly remove screen from frame. Tape and adhesive is holding it on so work slowly and use heat gun if needed. Using pick or pry tool, slowly remove screen from frame. Tape and adhesive is holding it on so work slowly and use heat gun if needed.
    • Using pick or pry tool, slowly remove screen from frame. Tape and adhesive is holding it on so work slowly and use heat gun if needed.
  9. For the most part, this teardown is pretty straightforward with the headphone jack fused to main board. The display looks to be fused to the screen so replacement of either means replacement of both.
    • For the most part, this teardown is pretty straightforward with the headphone jack fused to main board. The display looks to be fused to the screen so replacement of either means replacement of both.
Codyhatch24
Участник с: 26.12.2013
201 Репутация
1 Guide authored
Команда
Android Alliance Member of Android Alliance
Community
73 членов
Автор 476 руководств
Комментариев: 2
If there's anything I can add to help make this more clear cut and easy to follow let me know as this is my first attempt at a guide.
Codyhatch24 - Ответить
My rezound glass is cracked . It still operates fine but I would like to replace the glass. I ordered a glass from Amazon but it has a connection tail that I don't understand how to install?
Lee Ferguson -
Просмотр статистики:
За 24 часа: 1
За 7 дней: 2
За 30 дней: 5
За всё время: 3,754
