Введение
This product teardown will require pliers, a Phillips head screwdriver, a Y-head screwdriver, and a flathead screwdriver. Certain components will require some prying, so be prepared. You will also need some grip paste available, as some screws are placed very tightly in their spots.
Выберете то, что вам нужно
Unscrew the 10mm screws securing the plastic handle cover using a size PH1 screwdriver.
Unscrew the metal hot plates from the plastic covering using a size PH1 screwdriver.
The screws are 12 mm long.
Unscrew the plastic handle cover using a Special Key Tri-wing.
The screws are 9 mm long.
Now the metal plates are loose from the plastic cover. The plates need to be moved until the end of their hinge slots to slide them apart.
The hinges are very easy to take apart, once it is loose from the plastic cover.
Separate the snap fit and remove the light covers.
Remove the cords of the lights by pulling them out of their snap fit.
Remove the light covers by pushing them out of the plastic cover.
The lights are being taken out very easily with not much pressure.
Remove the press latch by using a screwdriver; add some pressure to it to get the latch loose.
Unscrew the heating element covers using a size PH1 screwdriver.
Remove the heating element covers from the plates.
The screws are 5 mm long.
Unscrew the heating element wires from the hot plates using a PH1 screwdriver. The screws are 5 mm long.
Remove the heating elements using a Phillips head screwdriver, and put this screwdriver under the heating elements.
