Введение
This guide will show you how to teardown the handle to access the power button and motherboard.
This teardown is not a repair guide. To repair your Hoover LiNX, use our service manual.
  1. Remove the single 15mm Phillips #1 screw from the handle.
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Remove the handle by pulling it up.
    • Remove the handle by pulling it up.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove two 15mm Phillips #1 screws from the handle.
    • Remove two 15mm Phillips #1 screws from the handle.
  5. Use a plastic opening tool to carefully pry the black cover off of the handle. Use a plastic opening tool to carefully pry the black cover off of the handle.
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  6. Remove five 15mm Phillips #1 black screws from the handle. Remove five 15mm Phillips #1 black screws from the handle.
    • Remove five 15mm Phillips #1 black screws from the handle.
  7. Remove the silver plastic cover using the plastic opening tool. Remove the silver plastic cover using the plastic opening tool.
    • Remove the silver plastic cover using the plastic opening tool.
Mark Nelson
Участник с: 25.01.2018
392 Репутация
Автор 2 руководств
Команда
USF Tampa, Team S7-G4, Passmore Spring 2018 Member of USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 7
За 30 дней: 35
За всё время: 620
