Введение
With the Huawei Mate 10 launch right around the corner, we thought this would be a good time to demolish inspect its predecessor, the Huawei Mate 9, released in November 2016. Join us for a closer look inside this phablet, and let's see if we can get a foretaste of the Huawei Mate 10.
Bored while waiting for the Mate 10? Come visit with us on Facebook, Twitter, and Instagram to stay up-to-date on all things repair!
Выберете то, что вам нужно
What's in the aluminum body of the Mate 9?
HiSilicon Kirin 960 SoC with an octa-core Cortex-A73 CPU and the Mali-G71 (MP8) octa-core GPU
Dual OIS camera system with Leica lenses providing 20 MP and 12 MP with ƒ/2.2 aperture
The smallest display of the Mate series with a 5.9" IPS LCD and 1920 × 1080 resolution (373 ppi)
64 GB internal storage, expandable via microSD to 256 GB
4000 mAh battery
The cold, grey finish on our Huawei Mate 9 gives us chills as we start the teardown.
On the backside, we spy (or get spied by) the second-generation Leica Dual Camera. Huawei says that it "renders images in unprecedented detail." At the moment it's beating us in this little staring contest, but we'll have the last laugh when we dig it out for inspection.
The fingerprint sensor lives on the rear of the phablet, right below the camera. Huawei's lab tests say it's 20% faster when compared to the sensor on the Mate 8.
Before we commence with disassembly, we line up the Mate 9 next to its closest sibling, the Huawei 9 Plus—which is only slightly smaller, with 0.4 fewer inches on the display diagonal. We tend to prefer the more contoured (and modern looking?) back of the Mate 9.
The first steps of the disassembly are rather unexciting, but give us a little more time to admire the sleek design of the Mate 9.
We remove the SIM and SD card tray—which (depending on your preference) can hold either a second nano SIM card, or one SIM and one SD card with up to 256 GB of additional storage.
The precious inner workings are protected by two seemingly Apple-esque pentalobe screws—only they're not, because they have six lobes each.
Time to open up, mate!
Инструмент, используемый на этом этапе:iFixit Opening Tool$1.99
With the screws off, we take
the biggest knife we can findan Opening Tool to pry open this phablet. -
No other tools needed, and we're in … looks like the inside of a phone to us! There is one flex cable which still connects the back cover with the main assembly of the Mate 9.
This single flex cable is responsible for the flashlight, the fingerprint sensor, and the volume and power buttons! What a versatile beast!
Инструмент, используемый на этом этапе:Phillips #000 Screwdriver$5.49
Before we can start with the removal of anything essential, we need to get rid of a bunch of Phillips #000 screws and a piece of black adhesive covering the flex cables.
After we say goodbye to some metal brackets, we can start to expose the motherboard by unplugging the display and motherboard flex cable, battery cable, and the antenna cable.
The motherboard removal is a piece of cake. Finally we can check out the chipset of the Mate 9!
But before getting to the chips, we want to take a look at the Mate's two cameras (well, three to be exact)—starting with the 2nd generation Leica Dual Camera!
The front camera comes out next, after we free it from its little bit of adhesive. Time to point our camera at this camera so we can camera camera camera.
Headlights on! It's chip time!
Layered underneath the 4 GB of LPDDR4 Samsung RAM (K3RG2G20CA-MGCJ) lies a Kirin 960 (likely Hi3660) octa-core CPU with a Mali-G71 GPU
64 GB of Samsung UFS flash memory (KLUCG4J1EB-B0B1)
Maxim Integrated MAX13042E 100 Mbps 4-ch. translator
NXP Semiconductor PN64 (PN551) NFC controller
HiSilicon Hi6403 audio codec
Maxim Integrated MAX14689 DPDT analog switch
Maxim Integrated MAX98925EWV mono class-DG audio amplifier
And on the back side:
Skyworks SKY78113-1, SKY78117-14 and SKY78114-14 for WCDMA / LTE bands
HiSilicon Hi6362 RF receiver (one more on the front side likely)
HiSilicon Hi6421 power management IC
HiSilicon Hi6422 power management
HiSilicon Hi6523 power management
Broadcom BCM4774IBG2G location hub chip
Broadcom BCM43455XKUBG 5G WiFi/BT module
IC Identification, pt. 2:
Skyworks SKY77360-12A quad-band power amplifier module
Skyworks SKY13552-669LF 2x SP6T antenna switch
Skyworks SKY13351-378LF GaAs SPDT switch
NXP Semiconductor BGU8009 GPS/GLONASS/Galileo/BeiDou low noise amplifier
Texas Instruments TWL80125 camera power management
Richtek RT1711H programmable USB type-C power delivery controller
Richtek RT9748 battery charger
IC Identification, pt. 3:
AMS AS3643 LED flash driver
Maxim Integrated MAX14654 high-current overvoltage protector
Maxim Integrated MAX77813 2 A buck-boost converter
Texas Instruments TPS61256A step-up converter w/ 2.3 A current limit
Texas Instruments TLV62084 2 A step-down converter
Texas Instruments regulator (likely)
Skyworks antenna tuner
After peering into the heart of the Mate 9, we calm down a little and proceed with the more mundane removal of the motherboard flex cable and some connectors.
A daughterboard falls into our hands, and with tears in our eyes, we see—the USB-C port is soldered to it.
Today's teardown tip is: don't stop 'til you get enough loudspeaker. This one supports the earpiece speaker in the display for a full audiovisual experience—when it's not on the teardown table, anyway.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
As we examine the battery our heart beats a little bit faster for a second, as we only see a single adhesive strip we need to pull out...
....Well we've been pleased too early. Right under the battery is a big, mean piece of adhesive we need to combat. Luckily our Plastic Cards come in handy!
Now that the battery is out, we can compare it to its competitors! Fully topped off, this 3.82 V, 4000 mAh cell will deliver up to 15.3 Wh of power. The new iPhone 8 Plus has only 10.28 Wh.
With the primary components laid out for inspection, we're calling this teardown a success.
We tried somewhat less successfully to separate the display from the frame. This procedure is nothing to look forward to, so better not crack the glass.
- Most of the components—like both camera units, the loudspeaker, and the USB board—can be replaced. Even the proximity sensor and the NFC antenna are modular.
- Despite the annoying hexalobe screws, the Mate 9 comes with only a few standard Phillips screws on the inside.
- The battery is trapped behind some flex cables and is glued tightly into place, but still can be swapped out when its power starts to fade away.
- Although we are happy to find a headphone jack, it is soldered to the board and calls for special soldering skills if it should fail.
- Replacing a broken display, one of the most common repairs, will be one of the most difficult ones on this phablet.
Заключительные мысли
Уровень ремонтопригодности
(10 легче всего ремонтировать)
8 Комментариев
Where can i get huawei mate 9 schematic?
Bei meinem Huawei Mate 9 ist das Wifi Modul defekt. Muss man dafür das komplette Motherboard tauschen oder ist es möglich das Modul abzu lösen und durch ein Ersatzteil zu ersetzen?
Hallo. Es ist unwahrscheinlich, dass du das einzelne Modul austauschen kannst. Es ist ans Motherboard gelötet und es wird auch schwer sein, es als Ersatzteil zu bekommen. Du kannst versuchen herauszufinden, ob tatsächlich das Modul oder nicht etwa die Wifi Antenne defekt ist. Diese kann getauscht werden und ist als Ersatzteil erhältlich.
Hallo
Wie heißt das Bauteil , welches oben rechts zwischen dem ausgebauten Lautsprecher und der Frontcamera liegt im Bild unter Schritt 13.
kann man dieses auch einzeln kaufen?
Mit freundlichen Grüßen
Hallo Kite fun,
das Teil rechts des Lautsprechers ist der Licht und Näherungssensor (Proximity sensor), das Teil links davon ist ein Mikrofon zur Rauschunterdrückung (noise canceling). Bei dem Mikrofon gilt es zu beachten, dass die meisten Ersatzteile ohne Dichtung geliefert werden und diese übertragen werden muss. Generell solltest du beide Teile im World Wide Web mit etwas stöbern finden können ;)
Is there any difference between the mate 9 and the mate 9 pro version, parts wise?
Yeah the usb boards are different for sure, I ordered a replacement for mine but was sent the pro version didn't realise until I opened it ?
