Выберете то, что вам нужно
Видео обзор
Remove the battery door—it's fastened tightly by clips. Free the clips with your fingernail or a pry tool.
Remove the rear camera and front camera.
Remove the power flex.
Credo sia un dissipatore, non penso sia un problema
Remove the battery. There is strong adhesive under the battery—work carefully to pry it free and be careful not to puncture the battery.
Try an iOpener or hairdryer to heat the adhesive behind the battery. This softens the adhesive, making it easier to release the battery.
Remove the sensor flex. It's covered under the digitizer flex and fastened by adhesive.
10 Комментариев
Sir sent me p8 lite LCD light track
P8 lite lcd light sulution
Can you help me please. Do you know where is the wifi antenna?
Thank you very much for this excellent tear-down. It made it possible for me to change the battery on this model. It took me 90 minutes to do it.
