Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Видео обзор
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Huawei Phone p7, воспользуйтесь нашим сервисным руководством.
  1. Remove SIM card trays.
    • Remove SIM card trays.
  2. Remove back cover. Remove back cover. Remove back cover.
    • Remove back cover.
  3. Remove battery connector securing bracket. Remove battery connector securing bracket.
    • Remove battery connector securing bracket.
  4. Remove battery. Attention: Be careful with the adhesive and the flex under the battery. Remove battery. Attention: Be careful with the adhesive and the flex under the battery. Remove battery. Attention: Be careful with the adhesive and the flex under the battery.
    • Remove battery. Attention: Be careful with the adhesive and the flex under the battery.
  5. Twist off the screws and remove the top securing bracket. Twist off the screws and remove the top securing bracket.
    • Twist off the screws and remove the top securing bracket.
  6. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  7. Release connector and remove front facing camera. Release connector and remove front facing camera.
    • Release connector and remove front facing camera.
  8. Release the connector and pry to remove headphone jack assembly. Release the connector and pry to remove headphone jack assembly.
    • Release the connector and pry to remove headphone jack assembly.
  9. Release power flex connector and LCD screen connector.
    • Release power flex connector and LCD screen connector.
  10. Twist off screws and remove bottom securing bracket. Twist off screws and remove bottom securing bracket.
    • Twist off screws and remove bottom securing bracket.
  11. Remove motherboard.
    • Remove motherboard.
  12. Remove rear facing camera by the way.
    • Remove rear facing camera by the way.
  13. Remove loudspeaker assembly. Remove loudspeaker assembly.
    • Remove loudspeaker assembly.
  14. Remove earpiece speaker.
    • Remove earpiece speaker.
  15. Remove power flex.
    • Remove power flex.
  16. Done.
    • Done.
    • We are sorry that didn't separate the screen from mid-frame. Because we can't open a gap between them even after a long time heating and many times try. It's said there is glue but not the sticker around the screen. So if operate with force, it's at high risk to break that good screen and scratch the frame.
    • But you can do it freely when you have cracked the screen and need a screen replacement.
Sophia
Участник с: 25.03.2014
42 746 Репутация
Автор 62 руководств
Комментариев: 3
Bonjour,
La vitre de l'objectif de l'appareil photo arrière de mon P7 est complètement griffée, j'aimerais bénéficier donc de la "vitre" du vôtre. Je n'ai besoin que de la première fine couche je pense ainsi que l"outil nécessaire... Est-ce possible? Merci
bonjourezjuju - Ответить
Hi
Thanks for the great tutorial. I was getting very weak reception with my P7 and I disassembled my phone today and replaced the antenna flex cable but it didn't make a difference; Can you please tell me where is the antenna for gsm located in this phone?
Saeed Esmaelzadeh - Ответить
Hola
Excelente tutorial, bastante completo y muy bien explicado.
para los que estan buscando cambiar el display solamente les agrego que no es necesario desmontar toda la placa base (tarjeta logica) con despegar la bateria y desconectar el flex es suficiente, ya lo demas con presicion y el calor adecuado pueden despegar la parte delantera.
Irbing - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 94
За всё время: 18,790
