Введение
This guide explains how to take apart the KAMBROOK 1.7L BPA Free Kettle , so you can take those part off by yourself.
Выберете то, что вам нужно
Put the device on the table.
CAUTION: Make sure the cord is not plugged into the outlet in order to prevent electrocution.
CAUTION: Make sure there is no water inside the kettle.
Pry down the fixed black circle with a screwdriver
Caution: Be careful of the tension.
Pry a slit between the kettle body and metal guy with hammer and screwdriver slowly.
Cut the rubber band in two halves and take them off.
Finally, take the metal guy off.
After you open the top cover, screw down 2 screws at the bottom of it, then you can get the whole cover off easily.
Caution: there have some components inside. DO NOT LOSE THEM!
Remove 3 white rubber mat with tweezers.
Screw down three screws off below rubber mats.
The kettle is now fully disassembled.
