Введение
I broke my LG 25UM58-P LCD panel. Since there weren't any teardowns or disassembly guides online, it was only fitting to do one before it went in the bin.
Выберете то, что вам нужно
The base plate can be removed by undoing the screw as seen in the second image.
Captive D-Ring screw
The stand is secrured to the monitor frame with 2 Phillips screws.
The small cover needs to be pushed down to disengage the clip.
Slide up in order to reveal the screws.
2 x Phillips #1 screws
There are 2 Phillips #2 screws holding the lower trim, with the LG logo, onto the monitor.
To get the lower cover off, remove the screws as stated, then pull it out at each end, one at a time. At approximately what 100mm in from the screw hole, slide something non metallic (eg a plastic ruler) between the screen and the trim and push downwards which will eventually release the tab. There are two tabs on each side. The other tab is about 60mm from the edge of the control button in the middle.
The lower trim piece lifts off with some persuasion.
The screen is held on with an overengineered system of clip and tabs. The only method that personally worked, was to pry at the display and lever it out.
The guitar picks were used to hold the display panel up and prevent it from clipping back in.
If you hit from the stand attachment part (where you screw the feet) bottom part of the screen drops.
I found the best way is to place the monitor, screen down on a soft surface. Now, lift the screen so that the bottom edge is off the soft surface by 50mm then while holding the casing on the bottom edge, push the monitor base bracket, which is exposed in the middle, quite hard downwards and eventually the back will release. This avoids risking damage to the actual screen.
Once you work your way around the edge of the display, and release all the clips, the panel will be free.
The rear cover separates from the LCD panel, revealing the surprisingly tiny control board
Some close-ups of the clips and mechanism used to secure the rear cover to the LCD panel
The panel model appears to be: LM250WW1
The LCD itself has the part number: BBSU1V 3467C2
The rear housing is stamped with the part number: MCK67880501
A closer look at the mounting method shows that there are a series of plastic "rods" that slide into slots on the LCD panel frame. The "rods" then attach to the clips on the rear housing as seen in Step 8.
Judging by the markings on the motherboard, it appears that the same PCB is used for the 34UM58.
The part number of the board appears to be: 692M000F-002 63624404
4 x #1 Phillips screws are used to secure the hinge plate to the back of the LCD panel.
2 x #2 Phillips screws are used to secure the hinge itself to the LCD panel.
Carefully route the cables away, from the hinge panel.
With the 6 screws removed from the previous step, the hinge assembly can be lifted away.
The LCD panel itself can be separated from the backlight.
Part number: BBSU1V 3467C2
A fairly tricky monitor to disassemble.
I'm 90% sure that removal of the LCD panel from the housing/frame will cause it to shatter (if it wasn't already damaged).
Replacement panels are about the same cost as replacing the entire monitor itself, making repairs unfeasible.
4 Комментариев
Sorry to hear that happened. But it made for a really good teardown
I have 25UM57 internals are literally the same. same panel
Hi, quick question. Do you know if that long skinny board on the bottom has the T Con board integrated into it? Or is that located on the main board centered on the back? Any info would be helpful as I believe I have a T Con issue with mine. Thanks so much!
I quickly googled what the T-con is…
Do you know what specifically I should look for, maybe a chip? I’ll have a look through my unpublished pictures
