Введение
Here is a video teardown of the ThinkPad T410s.
Below is a step by step teardown
Выберете то, что вам нужно
Видео обзор
Remove Keyboard retaing Screw from bottom of system
Turn the system over and open the cover. Push the keyboard toward the back and lift it up. Slide it forward to rest it on the palm rest. Disconnect the ribbon cable.
Disconnect the two antenna leads from the Wireless WAN card. Remove the two retaining screws. Rotate the card up and pull it out of the slot.
Remeber which lead goes where Prior to removing it . Grey is usually MAIN , black AUX
Remove 14 retaining screws from back
The first 9 are required for bezel and touchpad removal .
M2 × 14 mm, wafer-head, nylon-coated (6)
M2 × 3 mm, wafer-head, nylon-coated (3)
The remaining need to be removed for base cover removal
M2 × 5 mm, wafer-head, nylon-coated (4)
M2 × 10 mm, wafer-head, nylon-coated (1)
Note: The FPC cable is attached on the underside of the keyboard bezel assembly. In some models, the Bluetooth daughter card is also attached on the underside of the keyboard bezel assembly.
Turn system over , open , remove 4 retaining screws and the work form one side , using spudger to remove chasis bezel
M2 × 3 mm, wafer-head, nylon-coated (4)
Remove 4 retaining screws
Remove the two retaining screws on the bottom of the system.
M2.5 × 6 mm, wafer-head, nylon-coated (2)
Unroute all the wires.
Remove the retaining screws.
Carefully lift the LCD panel up and out of the chass
5 Комментариев
Uhm, sorry, what about the photos? I don't see any...
Still not seeing any photos accompanying the steps listed in the teardown.
The video shows a teardown of the T410s. It is a lot different from the T410.
