Инструменты для этого Разбора
Введение
This guide will help you break the W600 keyboard down. You will meet tons of glue in this process.
Do not expect this will help you to repair the keys: they are mounted tightly onto the case and are unable to disassemble.
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Lenovo W600 Keyboard, воспользуйтесь нашим сервисным руководством.
  1. Take off the protective stickers on the four corners Use a Phillips screwdriver to remove all five screws on the keyboard
    • Take off the protective stickers on the four corners
    • Use a Phillips screwdriver to remove all five screws on the keyboard
    • Insert a word screwdriver into one corner and move around to break all the hot glue. You may need to use steel rulers to break the hot glue between the keys and the backplate.
    • After struggling for a while you should be able to take the backplate off.
  2. Unplug the FPC cable. Use the same method as removing the backplate to break the hot glue between the keys and their backplate.
    • Unplug the FPC cable.
    • Use the same method as removing the backplate to break the hot glue between the keys and their backplate.
    • No more teardown process is possible without breaking the case of the keyboard.
_ Lithane
Участник с: 18.08.2017
101 Репутация
1 руководство автора
Один комментарий
i am experiencing a problem with my levovo w700 laptop keyboard. it is the problem as seen in this youtube vid - https://youtu.be/qmMcfFHCM60
any solutions.
i am using windows 7
Mr Keith S Boyd - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 697
