Инструменты для этого Разбора
Введение
The body of the guitar holds most of the main components and motherboards.
This teardown is not a repair guide. To repair your Les Paul Wireless Guitar, use our service manual.
  1. Remove batteries
    • Remove batteries
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Remove void warranty sticker The sticker is covering a torx screw
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  4. Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long. Push level, this will detach the back of the guitar from the front. Carefully remove the back of the body
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
Chris
Участник с: 18.10.2013
752 Репутация
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 3
За 7 дней: 12
За 30 дней: 59
За всё время: 4,528
