Выберете то, что вам нужно
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Logitech V220 - Cordless Optical Mouse, воспользуйтесь нашим сервисным руководством.
  1. Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: шаг 1, изображение 1 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: шаг 1, изображение 2 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: шаг 1, изображение 3 из 3
    • Wash your hands before replacing the battery to prevent debris getting into the mouse and damaging its internal components.
    • Orient the mouse so you are viewing its base.
    • Using your fingers, gently remove the USB wireless receiver by sliding it towards you.
    • USB removal will result in the power switch to be in its ON position.
    • With your fingertip, engage the power switch to its OFF position to ensure the mouse is not powered.
  2. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: шаг 2, изображение 1 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: шаг 2, изображение 2 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: шаг 2, изображение 3 из 3
    • Locate the four mouse pads.
    • Use the rectangular end of the metal spudger to get underneath each mouse pad, pry them up, and peel them off.
  3. Logitech V220 - Cordless Optical Mouse Teardown, Unscrewing the Mouse Housing Screws: шаг 3, изображение 1 из 1
    • Locate the four #0 Phillips screws where the mouse pads previously were.
    • Unscrew the four #0 Phillips screws with the Phillips #0 screwdriver.
  4. Logitech V220 - Cordless Optical Mouse Teardown, Separating the Mouse Housing: шаг 4, изображение 1 из 2 Logitech V220 - Cordless Optical Mouse Teardown, Separating the Mouse Housing: шаг 4, изображение 2 из 2
    • Once the housing screws are fully removed, slowly (and carefully) separate the top and bottom halves of the housing.
    • Rapid separation of the housing halves may result in damaging the power cables (red and black wires) and molex (white plug).
  5. Logitech V220 - Cordless Optical Mouse Teardown, Detaching the Top Mouse Housing: шаг 5, изображение 1 из 2 Logitech V220 - Cordless Optical Mouse Teardown, Detaching the Top Mouse Housing: шаг 5, изображение 2 из 2
    • Gently set the mouse halves down on a flat surface.
    • Secure the base half with one hand.
    • With thumb and forefinger, grab the end of the molex and pull it away from you until the molex is unplugged.
  6. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: шаг 6, изображение 1 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: шаг 6, изображение 2 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: шаг 6, изображение 3 из 3
    • Locate the one, scroll wheel, #0 Phillips screw near the very front edge of the mouse.
    • Turn the mouse 90 degrees clockwise.
    • While supporting the rear of the mouse base, unscrew the #0 Phillips scroll wheel screw.
    • Once the scroll wheel screw is fully removed, manually extract the scroll wheel and spring assembly.
  7. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel Spring: шаг 7, изображение 1 из 2 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel Spring: шаг 7, изображение 2 из 2
    • Locate the scroll wheel spring.
    • Use the tweezers to gently remove the spring by slowly tugging the spring away from the scroll wheel assembly.
  8. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: шаг 8, изображение 1 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: шаг 8, изображение 2 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: шаг 8, изображение 3 из 3
    • Locate and remove the circuit board screw.
    • Grip the edges of the circuit board.
    • Manually remove the circuit board from the base of the mold housing.
  9. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons Screw: шаг 9, изображение 1 из 1
    • Locate and remove the #0 Phillips screw in the middle of the mouse.
  10. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: шаг 10, изображение 1 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: шаг 10, изображение 2 из 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: шаг 10, изображение 3 из 3
    • Flip over the top half of the mouse housing so you are viewing underneath it.
    • Locate the mouse button hooks.
    • Rotate the housing 180 degrees clockwise.
    • Using the spudger, firmly push down on each mouse button until the mouse button is released from the hook.
    • Viewing the front of the mouse, the left and right mouse buttons should be detached from the housing.
  11. Logitech V220 - Cordless Optical Mouse Teardown: шаг 11, изображение 1 из 1
    • Hold the housing so you are looking down the battery slot.
    • Place the flat end of the spudger between the mouse buttons and the housing.
    • Pry off the mouse buttons.
Tyler Price
Участник с: 04/07/14
1 038 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 6-2, Forte Spring 2014 Участник Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 членов
Автор 20 руководств
Один комментарий
Tyler - Very good work on this and your other work on this mouse. I appreciate your attention to detail. I wonder if you are the T. Price who used to go to MacDonalds in U/A in 1995? Thanks again so much for your professional work!
Rik Lesel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 57
За всё время: 4,837
