Введение
Mac Pro Early 2009 8 Core.
Выберете то, что вам нужно
BackPlane Board and frontPanel Board linked by FrontPanel Board to BackPlane Board cable
Bluetooth antenna connected to the card on the Backplane board. One needs to be careful because if not connected the Antenna needs to be attached in order not to short-circuit the backpanel board.
A view of the power button that needs to be connected on the front panel board.
right fan in processor cage. Remember, two clips to take the a fan apart. Top and Bottom.
23 Комментариев
It is socket-b(LGA 1366)
I think it is easy to upgrade your CPU
It should be easy to upgrade a single-cpu Pro, they use standard lidded Xeons. I am planning on upgrading to W3690s in a couple of 4,1 machines that have had their firmware flashed to 5,1.
Please let me know how you handle that upgrade!! Or add a tutorial id vey much like to see that and maybe follow suit but im not very savy with these upgrades
Will -
Is it possible to easily remove and service right processor fan (the back one)? It makes too much noise, so needs some oil apparently. I didn't find any way to remove it.
