Инструменты для этого Разбора
Введение
We took apart the new 15" Retina MacBook Pro with the hopes that Apple made it more repair-friendly than the debut Mid 2012 model. Unfortunately, things didn't really work out in our favor; in fact, they took a turn for the (slightly) worse.
Even the headphone jack is now soldered to the logic board, which is definitely a component that can wear out over time. Users don't have to be malicious or aggressive when using the port — cyclical stress can cause it to fail either way.
For those of us who care about repair, do note that this is now your only 15" option; Apple stopped selling the non-Retina 15" MacBook Pro.
Want to learn more about repair, and inspire yourself to fix something? Check out iFixit.org.
This top-tier machine from Apple packs some impressive specs:
2.0 GHz quad-core Intel Core i7
8 GB of 1600 MHz DDR3L onboard memory
256 GB of PCIe SSD goodness
Intel Iris Pro Graphics
720p FaceTime HD camera
802.11ac Wi‑Fi wireless networking
Bluetooth 4.0
Easy-upgrade #2: Add a new AirPort card that supports 802.11ac Wi-Fi.
Apple's go-to provider of 802.11ac support is again at work. The Broadcom BCM4360 on this AirPort card enables operation on the 5 GHz band at speeds up to 1.3 Gbps.
A Broadcom BCM20702 Single-Chip Bluetooth 4.0 Processor gets Bluetoothy things done for your convenience.
Also in residence are a pair of Skyworks SE5516 dual-band 802.11 a/b/g/n/ac WLAN front-end modules.
One of the few differences: The 15" MBP now has a sleekified heat sink with just a single thermal pad, thanks to the more closely integrated GPU—which we attribute to the "Haswellification" process, as we call it.
The most noteworthy revisions come on the logic board, including the all-new Haswell Core i7 processor, Iris Pro Graphics, and Thunderbolt 2 support:
2.0 GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.2 GHz) with 6 MB shared L3 cache and Iris Pro graphics
128MB eDRAM cache
Elpida J4208EFBG 512 MB DDR3 SDRAM (16 chips for 8 GB total)
Intel DSL5520 Thunderbolt 2 Controller
Intel Platform Controller Hub
Cirrus 4208-CRZ Audio Codec, similar to Cirrus CS4207
Back of the logic board:
SK Hynix H5TC4G63AFR 512 MB DDR3 SDRAM
Broadcom BCM15700A2
Cypress Semiconductor CY8C24794-24LTXI Programmable System-on-Chip
Texas Instruments TPS51980
The headphone jack is now soldered onto the logic board—break yours (easily doable through normal wear and tear) and you're looking at a thousand dollar repair
The moment of truth is now upon us—is the battery any easier to take out than the previous, horribly glued-in disaster?
We're holding our breath as we gently test the waters with a plastic card...
...And half an hour and several skinned knuckles later, we exhale that breath in a great sigh of disappointment. The battery has the same excessive adhesive, and is just as nearly-impossible to safely remove as before.
So much for evolution of design.
MacBook Pro with Retina Display 15" Late 2013 Repairability Score: 1 out of 10 (10 is easiest to repair).
Proprietary pentalobe screws prevent you from gaining access to anything inside.
As in the MacBook Air, the RAM is soldered to the logic board. Max out at 16GB now, or forever hold your peace—you can't upgrade.
The proprietary SSD has changed to a PCIe format, but still isn't a standard 2.5" drive. However, it is a separate daughtercard, and we’re hopeful we can offer an upgrade in the near future.
The lithium-polymer battery is glued rather than screwed into the case, which increases the chances that it'll break during disassembly. The battery also covers the trackpad cable, which tremendously increases the chance that the user will shear the cable in the battery removal process.
The display assembly is completely fused, and there’s no glass protecting it. If anything ever fails inside the display, you will need to replace the entire, extremely expensive assembly.
Комментариев: 33
Hi all ! I have a one year old 15" retina MbP. Could it be possible, if the part becomes available somehow, to replace the Wifi card on my mac with an ac one like on the new model ? Or does the form factor change ?
Would really like to know the same, except, I have a last gen 13" Retina MbP. Thx for answers. (if you already know where to buy these cards, any help would be appreciated!)
You read my mind, I was wondering the same thing.
yeah, it would be really nice to take advantage of the 802.11ac technology!
