Выберете то, что вам нужно
2.4GHz wireless frequency
Max. control range: 30 meters
IR remote range: 10 meters
Built-in 500mAh battery
OK! let see what parts we have inside
nRF24LE1 - Ultra-low Power Wireless System On-Chip Solution
ADXL345 - small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16g
Two XV - 3700CB Ultra miniature size gyro sensor with high stability double output
IR TX diode
More parts
JTAG ?
Mini-USB port - as far as I know can be used only to charging
500mAh battery
USB Receiver
nRF24LU1 - Single Chip 2.4 GHz Transceiver with USB Microcontroller and OTP Memory
Прикрепленные документы
12 Комментариев
I Need to buy an IR replacement, could you please help me?
it is strange to me that you says it has a TX IR Diode, when the remote can also receive IR to "clone" the Signal from another remote.
thanks
it does not learn codes from Panasonic tvs (i tested) and from denon as i read here.
Confirm not work with Panasonic TV
I dropped the remote accidentally, now only works with the mini usb plugged in. any idea where and what to look for?
Thanks
Just had exact same issue that brought me here looking for disasembly how to. Only worked plugged in. Opened it up and glad to say its now fixed. My positive battery wire had broken off. Resoldered and tested. So far so good
legerrej -
Hello,
I lost my usb dongle. Is there a way to pair it to a new one or do i have to buy a new remote ?
I have the same problem! But mine just broke a very tiny crystal oscillator and I have no hope to find the right specs so I can buy another one.
Can we replace battery? Thank you for your answer.
Yes you can, order a 500mAh 3.7V rechargeable battery to replace. Just make sure to buy the right size (measure it after open)
I need a replacement usb dongle. Where do I get it from
