Введение
Microsoft has reportedly been working on the Surface Duo for six years. We can probably tear it down in less time than that, but with any brand-new form factor, there are no guarantees. Here’s hoping the Duo boasts the repairability of recent Microsoft sequels like the Surface Laptop 3 or the Surface Pro X—otherwise, we could be in for a long haul. Let’s get this teardown started!
For more teardowns, we’ve got a trio of social media options for you: for quick text we’ve got Twitter, for sweet pics there’s Instagram, and for the phablet of the media world there’s Facebook. If you’d rather get the full scoop on what we’re up to, sign up for our newsletter!
Выберете то, что вам нужно
Видео обзор
The long-awaited Surface Duo is here! For $1,400 you get two impossibly thin slices of hardware that you can fold up and put in your pocket... kinda. We're eager to see what's inside, and here's what we know about so far:
Two 5.6” AMOLED displays (each 1800x1350, 401 PPI)
Two batteries working in tandem, totaling 3577 mAh of juice
A Qualcomm Snapdragon 855 SoC paired with 6 GB of DRAM
128 GB or 256 GB internal flash storage
A single 11 MP f/2.0 camera, optimized for both front and rear use
WiFi-5, Bluetooth, 5.0, 4x4 MIMO LTE, and USB-C 3.1 connectivity hardware
360° hinges for unlimited folding potential
Unfolded, this "not a phone" is wicked thin—just 4.9 mm. For comparison, the famously so-thin-it-bends iPhone 6 Plus was 7.1 mm.
While it is a non-phone, the Duo features a removable SIM like other Surface devices. (No handy trap doors here, though.)
When folded, the Duo undercuts Samsung's original Fold by 7 mm (9.8 mm thick vs the Fold's 17 mm)—ludicrously thin, if less pocketable than, say, the Moto Razr.
The hardware honeymoon ends as we try to use the dysfunctional software to load a web page. Crashes, flashing screens, and flickers galore!
Thankfully, Microsoft has promised three years of software updates for the Duo—long enough to iron out lots of kinks. But will this ultra-thin, all-glass slab last that long in your hands?
Here's a view you won't see anywhere else, unless you have an X-ray machine from Creative Electron. While our teardown is just getting started, theirs is already done.
The Duo's entire left half bears a striking resemblance to a miniature iPad—great big battery, with a sliver of circuit board snaking around the right side.
The right half looks like nothing we remember seeing before—it's almost a solid wall of circuit board, with a little window in the middle for the second battery.
Opening pick, meet chassis gap. That's right, no heat or suction cups necessary just yet! This is way too good to be true!
...and it is. We quickly get bogged down in adhesive and have to break out the heat gun.
Further complicating matters, the panels are booby-trapped. Both batteries were firmly stuck to their respective rear panels, and tethered to the rest of the phone via fragile cables.
Careful carving through graphene cooling sheets and sticky strips of adhesive eventually does the trick, but there is almost a casualty.
We nearly destroyed an eensy flex cable that houses some indicator LEDs and connects the earpiece speaker to the circuit board nearby.
Alright, that ended up being much dicier than initial impressions led us to expect. Was this the right way in? Maybe the screens are supposed to come off first...
On the flip side, we find some easy purchase under a speaker grille—the cutout is conveniently in the case rather than a thin part of the screen, making the glass a bit less prone to cracking around our pick.
That said, this screen-first entry is no picnic. Hefty heat, some booby-trap cables, and unprotected displays under the glass make this procedure a doozy.
Eschewing those trendy and somewhat unproven folding displays in favor of a twin-screen configuration was bold, but potentially a lot of work if you ever have two cracked screens to repair. Double jeopardy!
Like some of the other specs in this device, the displays are flagship-tier by 2019 standards, which means no high-refresh rate here. Just two venerable 60 Hz AMOLED panels from LG Display.
Glass off, and right off the bat we spot the Duo's dual batteries. One battery in each half is shaping up to be standard for folding tech. Unlike other foldables though, the larger battery in the Duo is bonkers huge—easily double the capacity of its sibling.
The Duo's hemispheres are connected by two multi-strand interconnect cables routed through the hinges. They remind us more of old-school MacBook display cables than the flat ribbon cables we've seen in other hinges.
Let's talk about battery replacement. Obstacle 1: glue. Lots. Obstacle 2: Tri-point screws. Yuck. Obstacle 3: One battery's connector is pinned underneath the motherboard.
It really doesn't seem like Microsoft had any thought of battery replacement in mind here. $1400 is a lot to shell out for any device, let alone one with a built-in death clock.
The larger of the two batteries clocks in at 10.37 Wh, and the smaller one at 2.89 Wh. That's good for a total of 13.26 Wh.
Both are quite fittingly labeled, "This component cannot be easily replaced by user." (So, you're telling us there's a chance!)
And now for the main event, chips! A lot of this is last year's silicon, but that doesn't mean it's not worth stopping to catalog:
Qualcomm Snapdragon 855, layered under 6 GB of SK hynix DRAM
128 GB Toshiba UFS 3.0 storage
Qorvo 78052 RF Fusion MHB front-end module
Microsoft X904163 display driver
Qualcomm SDR8150 LTE Transceiver
Qualcomm WCD9340 audio codec
Qualcomm PM8150 power management ICs
Hi, where can I find the replacement screen?
If you thought those last chips were cool, wait till you see what else we found:
Qualcomm QDM4670 front end module
Qualcomm QDM4620 front end module
Likely a Qualcomm QPM4621 power amplifier module
Qualcomm QET5100 envelope tracker
Qualcomm Atheros WCN3998 802.11 WiFi transceiver
Likely Murata K29 front end modules
ON Semiconductor FSA4480UCX USB-C analog switch
A third round, our treat:
NXP Semiconductor NX3DV642 3-lane high-speed MIPI compatible switch
Qualcomm WSA8815 4 W, Class D smart speaker amplifier
Qualcomm SMB1381 battery quick charger
Nexperia 74LVC1G332GV-Q100 3-input OR gate
Nexperia 74HC1G08GW-Q100 2-input AND gate
STMicroelectronics LSM6DSO 6 DoF inertial measurement unit
The little divot on the side edge below the power button houses this stealthy, modular fingerprint sensor—easily accessed at this stage of disassembly, and not so easily accessed in any other sense of the phrase.
Next we twist away tons of teeny Torx screws securing the spine and hinges—thankfully not quite so intense as the original Surface Pro's ninety screws, but it's still a workout.
After a final de-boning, the two big wings are free to fly away from the central spine.
do you know how the reader part itself is attached to the board? my reader has fallen off
Two geared hinges straddle the great divide and cling to each side's stabilizer bars with a trio of screws.
The board interconnect cables dip into each hinge housing as they cross over to the other side, preventing them from being pinched as the Duo performs its folding tricks.
It all makes for a refreshingly simple hinge design compared to those we've seen in other foldables. It's sort of like of like a miniature 360° laptop hinge, cable routing and all.
It's time to fold up our toolkit and reflect. What did we learn?
Where Samsung and Motorola spent thousands of hours crafting elaborate hinges, external micro-screens, and hold-back-the-flood dust sweepers, the Duo is refined simplicity.
It’s a bold, impressive idea, even if it was a bit of a mess to take apart.
As with prior first-generation Microsoft portables, the thin, premium, category-creating Duo is not something meant to be repaired, maybe not even by Microsoft.
Recent Surface devices have shot up the repairability charts, so we’re hopeful that this is just the first chapter in the Duo story.
Enough talk, let's give this thing a score. We'll give you a hint: it's Duo.
- Displays and back glass covers can be replaced without disassembling any other components.
- Batteries are glued and require extensive disassembly to service.
- The USB-C port is soldered directly to the main board.
- Uncommon tri-point screws secure key components.
- Delicate OLED panels are not well protected from accidental prying, yet must be removed for most repairs.
- Stubborn glue at all entry points complicates any repair attempt.
Заключительные мысли
Уровень ремонтопригодности
(10 легче всего ремонтировать)
9 Комментариев
Innovative product.Inner parts looks good build quality
Wow, it’s kind of a mystery as to how repairable current Surface products are until you open them. On one end of the spectrum, we have the Surface Pro X and Surface laptop 3, and on the other hand, we have…this.
From what I know, pretty sure hardware development for this started (and likely finished) years ago and was mostly held back from earlier release because of lots of software changes and software issues, so I imagine a lot of design was done before Microsoft started focusing on easy repair like they did for the newer surface devices. Wouldn’t surprise me to see the second model be very different.
I’ve cracked the glass on the upper left corner of the right side screen. Do you know any any sources where i can buy the replacement glass? I found a source in India but they do not ship out of country. https://www.maxbhi.com/ Need a source that will ship to the US.
Anyone know where you can buy a replacement plastic frame? The charging port area of this is notoriously bad for breaking because it's so thin.
It's purely cosmetic. Take a scalpel, clean up both sides and call it a day. Not worth trying to fix that.
And if I could find a source for screens, I would attempt to fix my left one. Ridiculous the only option is to pay $650, especially when you can buy the whole phone from buydig for $480 or 460. Forget which. Otherwise my phone is e-waste. Sigh.
Ryan C -
My screen is cracked on the front and it won't even show any thing on them when I open it up
I got the same from https://www.xparts.in, it was good.
