Microsoft Surface Keyboard (WS2-00025) Teardown
Выберете то, что вам нужно
  1. Microsoft Surface Keyboard (WS2-00025) Teardown, Microsoft Surface Keyboard Teardown: шаг 1, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown, Microsoft Surface Keyboard Teardown: шаг 1, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown, Microsoft Surface Keyboard Teardown: шаг 1, изображение 3 из 3
    • The box is a scaled representation of the product. It's pretty much spot on.
    • It's a box - no It's a keyboard - no it's a box...
  2. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 2, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 2, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 2, изображение 3 из 3
    • Why the teardown? I received this keyboard from a "used" ebay listing, and it turned out to have a broken key.
    • The key tabs that hold the key to the base of the keyboard were sheared off, making repair of that beloved windows key pretty much impossible.
  3. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 3, изображение 1 из 1
    • Hidden under the left-hand side of the keyboard is the Bluetooth sync button.
  4. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 4, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 4, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 4, изображение 3 из 3
    • The back of the keyboard features a screwless battery compartment and not much else.
    • The battery cover is held in place by neodymium magnets and the metalized plastic coating on the cover.
    • The solid click of the battery compartment.
  5. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 6, изображение 1 из 1
    • Before I tear apart a product, I like to take the time to analyze the exterior construction and overall build of the item. This gives me a better idea of how the product was assembled and mass produced.
    • The best way to do this is by looking for seams or imperfections in the build construction.
    • Does the part bow or flex when a small stress is applied? Are there any large gaps in the build? Are there any obvious stickers covering fasteners?
    • This is how I pictured the keyboard to be constructed in my head. I had a feeling that it was one gigantic glued and snapped together assembly, but I needed to verify that first.
  6. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 7, изображение 1 из 2 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 7, изображение 2 из 2
    • After inspecting the seams, I check under the stickers and glued-on rubber feet. Still no signs of screws.
  7. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 8, изображение 1 из 1
    • It would be quite underhanded to put screws under the keys. Luckily that is not the case here.
    • To remove a key, wedge a plastic spudger under the key from the top most edge. Apply a bit of downward pressure on the spudger to lift the key. The key should make popping sounds and unlatch from the metal clips underneath the key that hold it to the keyboard frame.
    Were you able to reattach the keys without issue?
    xfMike - Ответить
    Yes. The keys reattach like most laptop keys. Align the key up as best as possible and then put a little downwards force, from bottom to top of the key. The key than latches into place and you will hear a “clicking sound.”
    Anthony Kouttron - Ответить
  8. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 9, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 9, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 9, изображение 3 из 3
    • Fearing the worst, I cut off a strip of wax paper and fully removed the bottom most rubber foot of the keyboard.
    • Still no screws in sight.
  9. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 10, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 10, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 10, изображение 3 из 3
    • The fit and finish on this keyboard is quite good - too good in fact. There is practically no room to fit a prying tool in any seam of the keyboard.
    • With the amount of double sided tape and glue inside this keyboard, it would be wise to use an iOpener tool or heatgun before beginning to pry open the keyboard.
    • I used a heatgun a bit later into the prying process because I was fearful of melting and deforming the back plastic of the keyboard. Luckily, adjusting the heatgun to its lowest setting activated the glue enough to become pliable.
  10. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 12, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 12, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 12, изображение 3 из 3
    • Now for the prying bit. Ready your barrage of prying tools! I used plastic spudgers, metal spudgers, plastic cards, and X-ACTO knifes to get this open.
    • The gap between the aluminum shell and plastic rear plate was so tight I had to use an X-ACTO knife with square-headed No. 18 Blade to widen the gap enough to slide in my metal spudger.
    • Important note: Don't ever pry with an X-ACTO knife, the blades are not meant for prying. If you pry with them, they will crack and can potentially cut into your hand.
  11. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 13, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 13, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 13, изображение 3 из 3
    • Only after applying heat was I able to get anywhere with prying.
    • I'll put it this way: two metal prying tools is simply not enough! Thankfully I had some spare giftcards lying around :D
  12. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 14, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 14, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 14, изображение 3 из 3
    • With a few more rounds of heat and prying I was finally getting somewhere.
    How long did you need to leave the heat on one spot? I'm trying to open the Surface ergonomic keyboard and the glue still seems rock hard
    john hills - Ответить
    Hi John. While I used a heatgun to open up this keyboard in this teardown, it’s very easy to deform the plastic permanently if you use too much heat. I had a lot better success in later teardowns with using a 115v medical blanket heater. You can find them at your local drug store like riteaid and walgreens. The heaters are designed to wrap around a body part, like an arm. In this case, you literally just wrap the keyboard and it softens up the glue. After an hour or so, take the keyboard out of the blanket heater and torque it a bit either way. You should hear popping sounds, the sounds of the edges yielding. At this point, take a plastic spudger, insert it near the edge and pry a bit. The keyboard should give in and you should be able to disassemble the keyboard in a very clean manner. I did this with the microsoft modern keyboard and it worked great. It even fit right back together. I will be making a guide soon on the process.
  13. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 15, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 15, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 15, изображение 3 из 3
    • The two main halves started to separate with some persuasion.
    • Giftcards really come in handy. They allow for some prying action without damaging sandwiched parts. If I used a metal spudger for this step, I could have risked tearing the one ribbon cable inside this keyboard. Save your giftcards!
  14. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 16, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 16, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 16, изображение 3 из 3
    • Finally apart!
    • With the keyboard apart, it is evident that Microsoft used double sided tape around each key and glue on the exterior keyboard edge.
  15. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 17, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 17, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 17, изображение 3 из 3
    • Close-up on the Battery compartment.
    • Neodymium magnets on both terminals and the top of the compartment!
    • The top magnets actually hold the AAA batteries to the top part of the plastic battery section. The only way to easily remove the batteries from the housing is to forcefully tap the top of the keyboard.
  16. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 18, изображение 1 из 2 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 18, изображение 2 из 2
    • The main PCB is rather small measuring 12mm x 170mm.
    • The back side of the PCB is sparse with just a ribbon cable connector and some solder joints.
    • The flex circuit board for the rubber dome keys terminates into a multi-wire ribbon cable which connects to the main PCB.
  17. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 19, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 19, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 19, изображение 3 из 3
    • The top side of the PCB is more densely packed than the back side. There is one main chip, some passive components, a battery connector, the Bluetooth switch and Bluetooth antenna.
    • Nordic Semiconductor nRF51822
    • 2 Pin JST battery connector
    • Button for Bluetooth pairing.
  18. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 20, изображение 1 из 2 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 20, изображение 2 из 2
    • A closer look at the Bluetooth antenna. Even though this looks more like a bracket than an antenna, it has been sized appropriately for the 2.4ghz bandwidth.
    • Real-time clock
    • Microchip Microchip VUA Power IC / Voltage regulator
  19. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 21, изображение 1 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 21, изображение 2 из 3 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 21, изображение 3 из 3
    • It is rather interesting that Microsoft intentionally left an empty ribbed space in the bottom compartment of the keyboard.
    • The Microsoft Modern Keyboard anyone?
  20. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 22, изображение 1 из 2 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 22, изображение 2 из 2
    • Continuing on the analysis of the surface keyboard, there is something special that Microsoft has hidden from its customers - right in plain sight.
    • *Incoming lyrical adaptations*
    • Why was typing meant to be hard?
    • Why ain't you a force of choice?
    • Why the whole world love my voice?
    • Why I try to tell em its my keyboard stroke, son
    • And you know why they made the new surface?
    • 'cause there's no backlight in the old ones - that's why!
  21. Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 24, изображение 1 из 2 Microsoft Surface Keyboard (WS2-00025) Teardown: шаг 24, изображение 2 из 2
    • One of the biggest complaints of the surface keyboard is that it doesn't feature a backlight.
    • It is rather sad that Microsoft chose to design a keyboard with several intentional iterations in mind, instead of just producing the best slim keyboard they could.
    • A quick design change such as adding a hole under each key, an optical diffusing layer and a few LEDs would have added a simple and functional backlight.
    • For further investigation into this keyboard, check out my Surface Keyboard Hacking Project
Финишная черта
9 участников успешно повторили данное руководство.
Anthony Kouttron
Участник с: 02/24/17
5 402 Репутация
Автор 5 руководств
Команда
salvagedcircuitry Участник salvagedcircuitry
Business
1 член
Автор 7 руководств
14 Комментариев
Man, how rude to use glue for a keyboard! I wanted to open my Surface Ergonomic keyboard in hopes it had JTAG or other diagnostic port that would enable me to twiddle with its brain, since macOS does not believe it is a keyboard but rather just a generic bluetooth HID :(
Thank you for sacrificing your keyboard to spare me the pain of discovering the hard way that my keyboard is glued together
Matthew L Daniel - Ответить
No problem! I’m glad you enjoyed the teardown. I sure wish they used screws instead of adhesive. It would make retrofitting a backlight far easier.
Anthony Kouttron -
If I discover anything interesting from probing that 10 pin unpopulated header I’ll be sure to provide an update.
Anthony Kouttron -
hey Anthony, i have the same problem with one of the keys (the big “0” on the numerical part). Did you find a solution for fixing the “key tabs that hold the key” that sheared of of mine as well?
Bas Flipsen - Ответить
Hi Bas! Unfortunately, I did not attempt to repair the broken aluminum key tabs that hold the key in place. However, I can point you in the right direction if you want to get creative and try a DIY fix. Carefully pop another key off your keyboard with something wood or plastic (like a plastic spudger) and analyze the metal locking tab design Microsoft implemented. Find another piece of aluminum of the same thickness and carefully cut out that tab shape. Try adhering your designed tab to the location where the broken aluminum key tab is situated. Epoxy or titanium putty should bond aluminum to aluminum. I would use a toothpick or sewing pin as an adhesive applicator. I think you will have success if you take your time and be patient. Good luck!
Anthony Kouttron -
Thanks Anthony… i will do my best. I was thinking along that way as well, but also about replacing the key with a fully or partially silicon alternative (using a printed 3D mold). I dont mind seeing the repair. I really enjoyed your Salvage Circuitry website and the disassembly of the keyboard. 0 out of 10 for opening?
Bas Flipsen -
how to connect this keyboard without a button. I have it with a broken button. someone will be grateful.
Adam Poplewski - Ответить
I almost have the same keyboard. The difference is that it has a Fingerprint sensor. I got the Microsoft Modern Keyboard with Fingerprint ID EKZ-00001. Got it from eBay too. I received it without issues but after my daughter spill my coffee on my keyboard, the keys below became sticky, almost to the point that whenever I press the key it goes back up very slowly. I might just get a USB Fingerprint Reader next time and a premium backlit keyboard next time I purchase.
Stephen Pascua - Ответить
Hi Stephen!
I have ironically disassembled the modern keyboard version as well. Disassembly went a lot smoother with different methods. I will probably upload a guide in a few weeks, but is boils down to this: Wrap keyboard completely in heated pad/blanket for 45min, torque/twist keyboard longitudinally, use plastic and stainless steel pry tools and then it opens right up with very minimal hassle. It even goes back together seamlessly. You wouldn’t even know it’s been disassembled. The key takeaway is use a heated pad/blanket. You cannot use hot air gun because it will melt keys or warp the keyboard. Heated blanket does not damage the keyboard whatsoever. Good luck!
Anthony Kouttron -
Hi Anthony! Love this guide - I’ve got the Microsoft Designer Bluetooth keyboard which looks incredibly similar, and I’d love to install a backlight onto it - do you reckon it’s possible with the space inside the keyboard?
sumjos - Ответить
My keyboard was no longer in use for few months. Now I need to use this keyboard, It's showing it's power on light and it’s blinking. It's also discoverable to connect but no keys are working I am not able to pair because it ask to enter a pin and keys are not working neither numpad nor numeric keys. Also, Caps lock light, Numlock lights are not working. Do you have any idea if I tear down to investigate, what should I clean/check? Please respond I really need to use this keyboard for now.
Thanks in advance.
Monis Azhar - Ответить
The ASD row of my surface keyboard isn’t working anymore even after i let it dry out for 2 days. It was pouring hard the other day and the ceiling right above the keyboard started leaking and I didn’t know about it. It was probably soak in water for an hour or more.
Any advise on what should i do? Or its time to say goodbye lol. Also just notice that there’s something loose in it when i shook it.
John - Ответить
Hi Anthony, great teardown, thanks! As you mentioned in a post above that you would be uploading the Modern Keyboard tear down as well, is that still something you would/will do? Or maybe amend this one, with possible difference? I was also wondering what temperature you set the heating blanket/pad to? Thanks a lot!
kn0 - Ответить
Our company has a few of these exact keyboards with keys that have popped out. Can we mail them to you for repair??
James Tuttle - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 56
За последние 30 дней: 294
За всё время: 24,091
