Видео обзор
- The opening procedure is straightforward, with a clever design that represents a dramatic improvement over its predecessors.
- The M.2 SSD is fully modular and easy to access.
- Torx Plus screws call for relatively rare drivers, but our standard Torx drivers worked in a pinch.
- Display access is well-prioritized, but must be replaced as an (expensive) complete unit—subcomponents aren't modular.
- While many components are modular, intricate layered construction makes them difficult to service.
- The firmly glued-down battery will be very difficult to service when it inevitably goes kaput.
Заключительные мысли
Уровень ремонтопригодности
5
Ремонтопригодность 5из 10
(10 легче всего ремонтировать)
Комментариев: 12
What is the purpose of the metal shield covering the trackpad and keyboard cable connectors? Is it to protect them or it is just a barrier to prevent repair?
Dinan Blueje - Ответить
It’s a form of electromagnetic shielding I assume. This is a very common design on smartphones but not on laptops, no idea why Microsoft does this.
Meng Ziyue -
Since there are heatpipes running all over these metal shieldings, it’s also reasonable to say that they act as a form of heatsink to even out the heat
Meng Ziyue -
@dblueje It’s likely a shield to protect against electromagnetic interference.
Finally, Microsoft has a laptop that can be opened.
Ethan Zuo - Ответить
That’s unfortunate, because you can’t remove the shield without destroying it(so it will never go back in again).
Dinan Blueje -
