Введение
Product # 42643
Universal Product Code 889028168349
Use a phillips #1 bit to remove 4 case screws.
For me, 1 was under a sticker, don't miss it
The metal case is 2 pieces. The front/sides are attached to the PCB, so slide the back/top/bottom piece off.
Pull out cable connector
Undo 3 Phillips #1 screws
Lift the board out
Main SoC: ASIX AX68002 product page
USB3 hub controllers (3x): VIA Labs VL817-Q7 datasheet
USB3 mux/demux switch: Pericom PI3USB302-A product page
HDMI2 switch: AlgolTek AG7210 datasheet
Serial NOR SPI flashes (4Mb, 2x - third on back): H&M/Bright Moon Semiconductor T25S40 datasheet, flash dump
Piezo speaker
Power distribution switch: Microchip MIC2026-1YM product page
Serial NOR SPI flash (1x - other 2 on front): H&M/Bright Moon Semiconductor T25S40 datasheet, flash dump
UART header. From L to R (remember this is the bottom!): VCC, device RX, device TX, GND. Bootloader and app output at 19200 baud, 8 data bits, 1 stop bit, no parity, no flow control
Debug jumpers for AX68002. Inner row from back to front: TEST_MODE, SYSCK_SEL, BURN_FLASH_EN, BURN_FLASH_921K
Outer row pairs with adjacent inner row pin to alter behavior. From back to front: pull-up (PU), pull-down (PD), PU, PD
