Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Инструменты для этого Разбора
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Motorola California Mobile Phone, воспользуйтесь нашим сервисным руководством.
  1. Remove the battery by sliding it down the rails to which it is connected.
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Find a flat head or Phillips head screwdriver.
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  4. Locate and unplug the black component of the antenna from the motherboard.
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  5. Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  6. Lift the motherboard out of its location in the front casing.
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
Andrew Lam
Участник с: 17.04.2012
35 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 9-46, Regan Spring 2012 Участник Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 7,297
