Инструменты для этого Разбора
Видео обзор
Remove back cover. It's easy, no adhesive and no screws.
Twist off all 14 screws together and remove the back frame easily. But the screws feature different lengths, you'd better remember their positions.
"You'd better remember their positions" Can't you make full guides on all your devices?
Hi there! This is a teardown, not a repair guide, check the full manual to see more complete guides, here for instance is a detailed screw removal step.
Just for completion as I made the same mistake today.
The longer screws are at the top and the bottom (2x4 screws) and the shorter ones (2x3) at the left and right side of the case.
Took me some time to find out which one goes to which position.
Release SIM&SD card reader connector and battery connector. And get the vibrator motor free from adhesive.
Can u explain little detailed about this step. Unable to release sim connector.
Loosen the platinum foil under SIM & SD card reader from plate. And then drag the stickers out which fix the battery.
Комментариев: 13
Nice work!
REQUEST: Next time you do a cell phone would you also shoot a straight down on top shot. The 3/4 is nice but I want to look straight down !
TY
P.S. Or just do a single TOP VIEW at the END like this one from Dillon ! Pretty Please!
Top View -
My Moto G just burned with 12 V from a cheap auto-recharger. But I lost very important data on the 8 GB memory. Is there a possible way to save the data?
Where can I get more information about GPS module and its antenna?
how to remove the external HDD? is there any way to recover data from it after detaching it from the device?
Give mi a seting
Mala motoG2 chi purn settings pahije
tanto el auricular y el altavoz son iguales si se invierte de posicion
what is issue if the moto g2 phone is heating at corner of near selfie camera when put for charging..
must be reply for my question…
what’s that small ribbon (looks like a thumbs up) coming out in image on step 13. I recently replaced a screen on my motog 2g and found this ribbon lying below battery but didnt know what to do with it. It is not a connector for sure as there are no sockets to connect there. my phone is working fine without my doing anything with that connector. just curious what it is for.
Also remove the SIM and SDCard!
Ben Low - Ответить
