Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Wanna know how to disassemble Motorola Moto X Force? Here show detailed steps.
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Motorola Moto X Force, воспользуйтесь нашим сервисным руководством.
  1. Remove it or it will be a barrier to remove motherboard. Remove it or it will be a barrier to remove motherboard.
    • Remove it or it will be a barrier to remove motherboard.
  2. Use heat gun to heat up back cover firstly. Insert metal opening tool to open a gap and cut adhesives around. Take care when sliding tool under the back cover, there are delicate antenna and other components that could be damaged by your glue slicing tool
    • Use heat gun to heat up back cover firstly.
    • Insert metal opening tool to open a gap and cut adhesives around.
    • Take care when sliding tool under the back cover, there are delicate antenna and other components that could be damaged by your glue slicing tool
  3. Use tweezers to cut adhesives underneath. Use tweezers to cut adhesives underneath.
    • Use tweezers to cut adhesives underneath.
  4. Twist off 17 screws by T3 Torx screwdriver. Take away rubber bracket securing NFC antenna and release NFC antenna connector. Take away rubber bracket securing NFC antenna and release NFC antenna connector.
    • Twist off 17 screws by T3 Torx screwdriver.
    • Take away rubber bracket securing NFC antenna and release NFC antenna connector.
  5. Take away rubber bracket securing MIC flex and release microphone flex cable connector. Take away rubber bracket securing MIC flex and release microphone flex cable connector. Take away rubber bracket securing MIC flex and release microphone flex cable connector.
    • Take away rubber bracket securing MIC flex and release microphone flex cable connector.
  6. After middle frame's separating from the rest of parts, side buttons are loose and easy to remove.
    • After middle frame's separating from the rest of parts, side buttons are loose and easy to remove.
  7. Release MIC connector. There are adhesives existed underneath. There are adhesives existed underneath.
    • Release MIC connector.
    • There are adhesives existed underneath.
  8. Use tweezers to pry this part up. Use tweezers to pry this part up.
    • Use tweezers to pry this part up.
  9. The vibrator is only fastened by the plastic bracket. The vibrator is only fastened by the plastic bracket.
    • The vibrator is only fastened by the plastic bracket.
  10. There are a little bit adhesives around, but you can peel this part easily. There are a little bit adhesives around, but you can peel this part easily.
    • There are a little bit adhesives around, but you can peel this part easily.
  11. Pry this part up. Pry this part up.
    • Pry this part up.
  12. Peel off the tape. Twist off 2 screws. Take care not to apply any lateral force to the motherboard to metal bracket electrical connector when removing the motherboard bracket. If abused, the tiny spring could break off at a later date and causing short circuits within the phone. The connector is to the right of the side button connector and above the copper film screened component.
    • Peel off the tape.
    • Twist off 2 screws.
    • Take care not to apply any lateral force to the motherboard to metal bracket electrical connector when removing the motherboard bracket. If abused, the tiny spring could break off at a later date and causing short circuits within the phone. The connector is to the right of the side button connector and above the copper film screened component.
  13. Release this two connectors carefully.
    • Release this two connectors carefully.
  14. The LCD assembly has two connectors, here is touchscreen connector. The LCD assembly has two connectors, here is touchscreen connector.
    • The LCD assembly has two connectors, here is touchscreen connector.
  15. This one is display connector. This one is display connector.
    • This one is display connector.
  16. Release signal cable connector. Pry the motherboard assembly up. Pry the motherboard assembly up.
    • Release signal cable connector.
    • Pry the motherboard assembly up.
  17. Moto X Force packs a 21-megapixel primary camera on the rear. Moto X Force packs a 21-megapixel primary camera on the rear.
    • Moto X Force packs a 21-megapixel primary camera on the rear.
  18. Use tweezers to release the connector. Use tweezers to release the connector.
    • Use tweezers to release the connector.
  19. With this sensor flex, you can wave your hand on the top of the screen to wake up the screen. With this sensor flex, you can wave your hand on the top of the screen to wake up the screen.
    • With this sensor flex, you can wave your hand on the top of the screen to wake up the screen.
  20. Non-removable Li-Ion 3760 mAh battery. Non-removable Li-Ion 3760 mAh battery.
    • Non-removable Li-Ion 3760 mAh battery.
  21. A 5-megapixel front shooter for selfies. A 5-megapixel front shooter for selfies.
    • A 5-megapixel front shooter for selfies.
  22. Be careful to pry this part up, because it tends to fall apart easily. Be careful to pry this part up, because it tends to fall apart easily.
    • Be careful to pry this part up, because it tends to fall apart easily.
  23. Use tweezers to cut adhesives underneath. Use tweezers to cut adhesives underneath. Use tweezers to cut adhesives underneath.
  24. Here is LCD screen with LCD supporting frame. They are attached tightly, so we haven't separate them. Here is LCD screen with LCD supporting frame. They are attached tightly, so we haven't separate them.
    • Here is LCD screen with LCD supporting frame. They are attached tightly, so we haven't separate them.
  25. Done.
    • Done.
Witrigs
Участник с: 24.11.2015
66 056 Репутация
Автор 386 руководств
Комментариев: 9
amoled
Danila Elchin - Ответить
Good afternoon,
Tell me what you can say on the problem faced by many users of the device.
When you connect the original or third-party charger with fast charging Functions or without fast charging function, and sometimes when using cordless phone charging on the charge indication is presented but charging rate is 1-3% per hour. This problem occurs on the Droid Turbo 2 and X force.
I would like to hear your opinion on this issue.
Vikulov Aleksander - Ответить
Several units are plagued by a vertical green line that appears on LCD (just search for Moto X Force or Droid Turbo 2 Green Line). Bad flex or bad LCD ?
NCQ - Ответить
There should be problem of lcd screen flex.
Witrigs -
I have a UK Moto X Force. I have noticed that the green line appears when You push harder between the screen and right loudspeaker hole. it disapears when I remove my finger. I hope this green line wont become permanent :/
Dxt D -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 45
За всё время: 17,777
