Выберете то, что вам нужно
The CitiZ is a compact coffee-making gizmo. Opening it requires a proprietary tool that Nespresso doesn't sell.
You can get into it with a pair of needle-nose pliers. The pliers I used aren't ideal — you want something that can get into the recessed slots.
There are six ovoid screws on the bottom case. The screws look like rivets, but they are actually oval.
You can painstakingly remove them with pliers. Take your time.
If you can't get pliers to work, other people have had success using superglue, melting a BIC pen into the shape of the screw, or machining a custom bit.
Now that the screws are removed, use a screwdriver or a spudger to pry the tabs holding the bottom case on.
The easiest place to get in is the power plug. Be careful not to nick it. (And make sure you're unplugged from the wall!)
The plastic strain relief bracket on the power cable is challenging to remove. Insert a small flathead screwdriver into the small slot on one side to disengage the tab.
Nespresso makes heavy use of spade connectors inside this machine.
Grab one side firmly with your pliers and pull on the other side of the connector with your fingers. Do not pull on the cable, because you can pull it free from the spade connector.
Thread the remaining tubes and wires through the bottom case to free it from the main unit.
Remove the bottom case.
Removing the outer shell requires some force.
There are a series of tabs on all four sides of the shell.
Start by using a flathead screwdriver or spudger to pop the first tab.
Work your way around the case, freeing tabs as you go.
The pump feed tube uses a clever retaining clip. Remove this clip with your pliers. It does not require much force.
Repeat this for the clip attaching the valve to the water heater.
Disconnect the power cable from the spade connector on the side of the water pump.
Remove the side panel from the other side of the unit. The tab positions are similar to the first side panel.
Remove the front spout.
Remove the top case. Be careful, the button cables are captive to the case. Disentangle the cables and set the top next to the frame.
Power cables, from left to right: heat (white), neutral (blue), pump (dark grey), pump ground? (light grey), line (brown).
Disconnect each cable with your pliers.
Slide the water pump out. The rubber vibration isolator doubles as a mounting bracket that neatly slides out from the plastic frame.
Remove the (rather over-engineered) silicon mounting bracket holding the coffee feed line in place.
Free the latch on the right side of the circuit board and then carefully lever it out.
Don't use too much force on the plastic bracket on top of the circuit board because there are two vulnerable capacitors on the rear left side of the board.
The BTB12 AC 12 Amp triac requires a large heat sink that is riveted onto the main board.
32 Комментариев
or you can make your own tool! See http://www.maultech.com/chrislott/blog/2...
Where is the heating element then?
Hi Junaho.
Did you have a look to Step 26 ?
I see, my bad.
