Введение
A teardown the NetGEAR 54 Wireless Router
Выберете то, что вам нужно
Flip the Net Gear wireless Router over remove four rubber tabs .
Place them to the side
Use a Phillips #00 screwdriver to remove the four screws.
Place them aside
Use a spudger on the edge of the clear hard plastic around the outer casing.
Use a spudger on the edge to push up the plastic casing.
Once the clear plastic casing is removed, place it to the side.
Remove the motherboard with bottom case. Then you are done.
2 Комментариев
bad quality images
bad teardown!
