Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Wig Ban's teardown of a Google Nexus charger 2012 (LG WCP-400). Originally provided as an answer.
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Nexus 4 Wireless Charger, воспользуйтесь нашим сервисным руководством.
  1. Remove the round rubber face from the charging orb
    • Remove the round rubber face from the charging orb
    • Behind the rubber face is a thin sheet of plastic, you'll need to pierce it to access the 4 screws holding the device together.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. The screws are located at 12 o'clock, 3 o'clock, 6 o'clock and 9 o'clock, just inside the outer ring.
    • The screws are located at 12 o'clock, 3 o'clock, 6 o'clock and 9 o'clock, just inside the outer ring.
    • You will need to unscrew these if possible, on my unit they were glued in and I was unable to unscrew them. Instead I used a drill with a 1/8" bit to drill them out.
    • If you drill them out be careful as they are surrounded by a PCB, though I drilled into the board a bit and it still functions. Once you remove the screws use the spudger to pry the shiny black plastic face off the base.
    • You will see the seam where the shiny and matte plastic meet on the unit. There are 4 plastic clips holding it down, once they are unclipped you can remove the shiny black faceplate exposing the charging coil and main PCB.
  4. Next gently pull up on the main PCB and swing it to the right. There are wires connecting the main board to the micro usb port beneath, so be gentle.
    • Next gently pull up on the main PCB and swing it to the right. There are wires connecting the main board to the micro usb port beneath, so be gentle.
    • You will see a single screw holding down the board with the micro usb connector, unscrew it and you're done.
David Spalding
Участник с: 12.11.2015
5 809 Репутация
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 2,160
