Выберете то, что вам нужно
Behold the glorious retro controller face, then forget about it because you will flip the controller for the rest of the teardown.
Use the size #1 Philips to remove the 7 screws on the back of the controller.
Use the size #0 Philips to remove the smaller screws in the controller pak slot.
Remove the back plate. You can now see the:
Power Input
Game Pak Slot
Trigger Button Assemblies
Z Button Assembly
Joystick Module
Using a spudger or similar tool, carefully pry the Z button assembly from the joystick module.
Remove the 3 size #0 screws holding in the joystick module.
Remove the joystick cable from the main board.
Remove the main board and trigger assemblies.
Your controller is now fully disassembled!
