Введение
Explanatory Guide of how to teardown a Nintendo GameCube.
This teardown is not a repair guide. To repair your Nintendo GameCube, use our service manual.
Flip unit over and locate the four screws shown in the second photograph.
  • Flip unit over and locate the four screws shown in the second photograph.
  • Remove four corner screws located on the underbelly of the unit using the Nintendo Gamecube bit tool.
Добавить комментарий
Pull bottom half of unit away from top outer casing.
  • Pull bottom half of unit away from top outer casing.
  • Depress clips and remove back panel as shown.
  • Carefully unclip controller ports in the front of the unit.
  • Ribbon Cable (in yellow) is still attached to the unit. Do not try to disconnect this cable.
I am looking to purchase a board for the controller ,can l and can give me the cost for Nintendo GameCube DS10460131B DOL-001
Roypolimeni87@Comcast.net. thank you.
Roy Polimeni - Ответить
  • Unscrew the two screws holding the fan assembly onto the unit using a Philips #2 screwdriver as shown.
  • Carefully remove the red and black wiring assembly from the fan unit by gently pulling the fan connector away from the fan as shown.
  • Remove four screws using a Philips #1 screwdriver as shown.
  • Carefully remove metal plates as shown in second photograph
  • Starting with the three screws located under the fan assembly, unscrew a total of twelve screws on the outer edge of the unit using a Phillips #2 screwdriver.
  • Carefully lift drive assembly off of the base.
  • Flip drive assembly over and remove 8 screws as shown.
  • Remove metal plate, careful to not disturb the brown wire (shown in yellow)
There's actually only 6 screws to remove-- two of the circled objects are placement pegs.
Kevin K - Ответить
  • Gently slide out black clip holding the brown ribbon in place. Then slide out brown ribbon as shown.
  • Carefully remove blue wire
  • Remove four screws with a #1 Phillips Screwdriver
  • Flip out circuit board as shown, being careful not to sever the red wire or the white ribbon cable (shown in yellow boxes)
  • Using a flat-head screwdriver or other long flat object, carefully release the four plastic clips holding the drive assembly together.
  • The last clip can be rather hard to find. Use a screwdriver as shown in the third image to get behind the plastic to release the last clip (in blue).
  • Lift metal plate off of drive assembly, again being careful not to sever the two wires still attached to the two halves of the drive assembly.
  • Next, flip and rotate the drive assembly so that it resembles the one in the third picture.
  • Using the screwdriver, release two more clips around the back half of the drive assembly.
  • The last clip doesn't need to be released, the top half of the drive assembly will slide away from the lower half.
  • Finish removing the top half of the drive assembly, be careful as this piece is where the two wires that should not be removed are attached to (unless you want to do some soldering).
  • Remove three final screws near the bars of the lens assembly. Once this is done the lens assembly can be removed.
  • Shown in the first picture is the lens assembly. In the second, the drive assembly without the lens assembly.
  • Congratulations, you're done!
agronbac
Участник с: 28.10.2009
603 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 6-2, Maness Fall 2009 Member of Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 членов
Автор 9 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 3
За 7 дней: 43
За 30 дней: 127
За всё время: 21,649
