Выберете то, что вам нужно
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Nintendo Wii Remote, воспользуйтесь нашим сервисным руководством.
  1. Nintendo Wii Remote Teardown, Starting off: шаг 1, изображение 1 из 2 Nintendo Wii Remote Teardown, Starting off: шаг 1, изображение 2 из 2
    • First remove the back part of the wii remote and the batteries. Then use the tri wing screw to unscrew the four small screws.
    • Next use a flathead screwdriver or maybe even your finger nails to pry apart the two pieces. There is a clip on either side of the d-pad which require the base piece to be squeezed inwards.
    • BE CAREFUL TAKING THE TWO PIECES APART! IF NOT DONE CAREFULLY YOU MIGHT END UP WITH ALL THE INNER PIECES FLYING EVERYWHERE!
    I broke off one of the plastic tabs despite my most careful finesse in separating the two halves. There has to be a correct way to do this.
    edwardsgreg - Ответить
    There definitely is. First off, the tabs aren't exactly off to the sides of the D-Pad. They're closer to being in between the D-Pad and the Power Button. If you have the ifixit Jimmy tool, you can feel for and then pop the tabs easily without breaking them. I know this is 2+ years later, but maybe it can help someone in the future.
    Biblio Technophile -
    Thank you for the follow up post. It in fact did help me. Cheers.
    oneman1775 - Ответить
  2. Nintendo Wii Remote Teardown, Remove the Sensor: шаг 2, изображение 1 из 3 Nintendo Wii Remote Teardown, Remove the Sensor: шаг 2, изображение 2 из 3 Nintendo Wii Remote Teardown, Remove the Sensor: шаг 2, изображение 3 из 3
    • You’re going to have two pieces and the sensor might be stuck on the motherboard side or the top side, but you still do the same thing no matter what side it’s on.
    • All you have to do to remove the sensor is just grab it and pull a small bit and it should come right out.
  3. Nintendo Wii Remote Teardown, Remove the “+” button covering.: шаг 3, изображение 1 из 2 Nintendo Wii Remote Teardown, Remove the “+” button covering.: шаг 3, изображение 2 из 2
    • Remove the “+” button covering. You also are going to want to do the same with all the other button coverings.
    • Not a step, just extra info The way the buttons would work is that you’d press down on the buttons which would then send a signal through the motherboard, and either the lights at the bottom would turn on or signals would be sent to the sensor which would then sync up with the sensor you would have up by your tv
  4. Nintendo Wii Remote Teardown, Button Covering removal: шаг 4, изображение 1 из 2 Nintendo Wii Remote Teardown, Button Covering removal: шаг 4, изображение 2 из 2
    • Remove the coverings, all you have to do is just pick them up with your fingers or you can use tweezers as well to do this.
  5. Nintendo Wii Remote Teardown, Remove the speaker.: шаг 5, изображение 1 из 3 Nintendo Wii Remote Teardown, Remove the speaker.: шаг 5, изображение 2 из 3 Nintendo Wii Remote Teardown, Remove the speaker.: шаг 5, изображение 3 из 3
    • Use tweezers to remove the speaker. To do this, grab the little tabs on the side and CAREFULLY start to pull it out of the slot so you don’t damage the tabs. After a couple of seconds of pulling, the speaker should pop right out.
  6. Nintendo Wii Remote Teardown, Remove the buttons: шаг 6, изображение 1 из 3 Nintendo Wii Remote Teardown, Remove the buttons: шаг 6, изображение 2 из 3 Nintendo Wii Remote Teardown, Remove the buttons: шаг 6, изображение 3 из 3
    • To remove the buttons all you have to do is get some tweezers and use the little ridges that pop up as something to grab and pop them out. You’ll want to take out the “1” “2” “-“ “+” the home button, the “A” button and the d-pad button
  7. Nintendo Wii Remote Teardown, Check point: шаг 7, изображение 1 из 1
    • Before moving on, make sure you have all your parts and that you haven’t dropped anything.
  8. Nintendo Wii Remote Teardown: шаг 8, изображение 1 из 3 Nintendo Wii Remote Teardown: шаг 8, изображение 2 из 3 Nintendo Wii Remote Teardown: шаг 8, изображение 3 из 3
    • To remove the motherboard, use some tweezers to grab one of the port walls and pull upward. Be careful to not damage the inside parts though!
  9. Nintendo Wii Remote Teardown, Removal of “B” button: шаг 9, изображение 1 из 2 Nintendo Wii Remote Teardown, Removal of “B” button: шаг 9, изображение 2 из 2
    • To remove the “B” button, just push upward on it so the little pegs can pop out from the wall. You can also just get tweezer and use it to pop the pegs out.
  10. Nintendo Wii Remote Teardown, The last little thingy: шаг 10, изображение 1 из 1
    • To have this be a complete teardown, there’s also this small piece at the bottom where the four lights would light up telling you if you’re player 1,2,3 or 4. You don’t realllly need to remove this piece but if you want to be thorough then go ahead.
  11. Nintendo Wii Remote Teardown, Done!: шаг 11, изображение 1 из 1
    • All your pieces have been removed! If you would like to put the wii remote together just follow this guide in reverse.
Ashley
Участник с: 04/13/18
526 Репутация
Автор 3 руководств
11 Комментариев
Thanks Ashley! Easy to understand and most helpful! Looking forward to discovering other teardowns you may have!
Erica Phillips - Ответить
What about the battery contacts in the back casing? How do you get those out?
John Breaux - Ответить
for the battery contact in the remote where the b trigger is, how do i remove it? the 2 i have are corroded there and i want to clean them
JADENk - Ответить
Its only in place with a bent back piece of metal. Best thing I've found to get in there and bend the metal back and pull it out slowly is with a penknife.
Stuart Bell -
I have bumped at the same issue. It seems you can't take it apart; I couldn't, at least. So, since I also had badly corroded contacts and the controller wasn't working anyways, I decided to give it a shot. Believe me, I've tested before posting here.
Try this: Disassemble the whole controller as normal. Remove the B button.
Now, you just have the back w/ contacts. Take a cup and pour alcohol vinegar in. Yeah, that one for salads. Sink the controller in the solution. I recommend doing so vertically, to not soak the black thingies. Inevitably, you will soak one of them, but it'll be ok.
You should notice bubbles coming out. That's the oxygen from reaction, means it’s working. Leave it for about 30-45 minutes.
[Continue…]
felipefigueira92 - Ответить
After that, even some particles of the alcalin may be found at the bottom. Wash the contacts preferably w/ only isopropyl alcohol to remove the excess vinegar, although I washed with regular water under the sink (to remove the smell in the plastic), then applied some alcohol and dried the excess w/ a cloth. The black thingie is like a sponge, be careful to dry it well.
Let it dry more for about one hour, just in case. After that, assemble it again, insert the batteries and voilà, working flawlessly.
I considered mine lost and had little hope about this method, but turned out fine, since I noticed there was no electronics in the back housing, just the contacts.
Hope this help you and others.
Disclaimer: Do it at your own risk, I am not responsible for any damage in your device. Just give a shout if it worked for you too and spread the word ;)
you can use a small screwdriver and your thumb to remove the battery contacts on the side of the b trigger. It is just pressed in.
thijs kunst -
Nice Teardown! Thanks worked perfectly.
Marko - Ответить
For all you people who are trying to get the other side of the battery terminals out, use something to lever the bottom of the domed bit & the two metal hoops/prongs up enough to get a grip on the metal with a pair of pliers. then just pull it out.
qwerty 9118 - Ответить
Out of interest, has anybody tried this with the wii motion plus remotes? Is it the same process?
Holly Morrow - Ответить
Does anyone know if these parts are available? I need the rubber piece that holds the 1 and 2 buttons in place.
James Finnegan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 209
За последние 30 дней: 953
За всё время: 49,131
