Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Nokia 2605, воспользуйтесь нашим сервисным руководством.
  1. Red arrows indicate which screws must be removed in order to get to the motherboard.
    • Red arrows indicate which screws must be removed in order to get to the motherboard.
  2. Take T5 torx and remove all 3 screws.
    • Take T5 torx and remove all 3 screws.
  3. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  4. Wedge a flat head in between the back and phone exterior starting at the bottom corners.
    • Wedge a flat head in between the back and phone exterior starting at the bottom corners.
    • As you move toward the top, remove the camera and volume buttons.
  5. Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip). Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
    • Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
Dorsa
Участник с: 07.11.2013
143 Репутация
1 руководство автора
Команда
University of Maryland, Team 1-7, Calloway Fall 2013 Участник University of Maryland, Team 1-7, Calloway Fall 2013
UMD-CALLOWAY-F13S1G7
3 членов
Автор 1 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 1,041
