Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Start by heating up the back glass. Ifixit's iOpener kit is very useful here. You can also use heating pad or heat gun
Take off the SIM tray, and start there. Use suction cup if avaliable
After you have made room for plastic card, finish the work by going around the glass with card
Start by screwing off all screws. There are 3 type of different screws.
11 pcs of longer black painted screws
10 pcs of shorter black painted screws
1 shiny metallic screw
After that, pop off bottom piece and then midframe
Remeber to disconnect battery connector first
Battery has pull tabs, so you should try this first
If pull tab breaks, you have to commit a pry of shame
Disconnect volume and power button connector
Disconnect connector on motherboard
Pry off the daughter board
There are 2 screws
1 longer black screw
1 standoff screw
After taking the screws off, you can disconnect antenna coaxial cables
Now you can take motherboard off
Make sure to push SIM-eject pin out first
Charging board is held down with 2 screws
1 black screw
1 golden screw
After taking the screws off, charging board is free
And now you are done, repeat steps backward to put everything back together
2 Комментариев
Mannaia Dio, mi ruvinasti!
Mannaia God, You ruined me!
