Введение
It’s the Nokia 8110 4G also known as the banana phone! Not only does this phone have an extremely cool sliding keypad cover, but you also don’t need to do anything special to get it open. We love an easy teardown and that’s what we got! Watch as we disassemble the Nokia 8110 4G.
Выберете то, что вам нужно
Видео обзор
- For the most part disassembly is extremely simple with only plastic clips, and standard Torx screws holding the phone together.
- The battery is easy to access and replace
- Several main components such as headphone jack, SD card slot, Micro USB port and vibrator are soldered to the motherboard.
- Getting to the display requires removing the front glass which is tricky to remove without damaging it.
Заключительные мысли
Уровень ремонтопригодности
8
Ремонтопригодность 8из 10
(10 легче всего ремонтировать)
2 Комментариев
这种玻璃很难移除而不会损坏它。
这块玻璃屏在被移除时很容易遭到损坏
Hong DING - Ответить
Very good teardown clip except did not show separation between tactile matte keymat and upper case.
Abbas Abdul Wahab - Ответить
