Инструменты для этого Разбора
Введение
This guide will show you how to completely teardown your camera.
This teardown is not a repair guide. To repair your Olympus Stylus 410, use our service manual.
  1. Locate the 2 screws on the bottom of the slider.
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Gently pull on the bottom of the slider until it comes off the lower track.
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Lift the slider up until it comes off the upper track.
    • Lift the slider up until it comes off the upper track.
  4. The slider should now be free from the body of the camera.
    • The slider should now be free from the body of the camera.
  5. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Use the spudger to peel off the outer metal band, starting from the bottom of the camera. The metal band it attached to the camera with glue in addition to screws.  Be careful not to bend the band when removing it from the camera.
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. The shutter button can now be removed. It is not connected to the camera and can be lifted off. The shutter button can now be removed. It is not connected to the camera and can be lifted off.
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  9. Remove the memory card. Locate and remove the 2 screws using a #00 Phillips screwdriver.
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  10. Use a spudger around the edge of the case to loosen it. Carefully wiggle the back case off. This may require a fair amount of force. Carefully wiggle the back case off. This may require a fair amount of force.
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  11. Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  12. While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required. Be careful not to completely pull the front case off because it will still be connected with wires.
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  13. Locate the gray compartment covering the flash. Position your flat head screw driver or small spudger underneath the tab that is keeping the gray cover on.
    • Locate the gray compartment covering the flash.
    • Position your flat head screw driver or small spudger underneath the tab that is keeping the gray cover on.
    • Gently lift the tab so the gray compartment becomes free.
  14. Use the spudger around the perimeter of the gray compartment to detach it from the front case. The gray compartment can now be removed from the flash unit. The flash unit can now be removed, and a new one soldered back on.
    • Use the spudger around the perimeter of the gray compartment to detach it from the front case.
    • The gray compartment can now be removed from the flash unit.
    • The flash unit can now be removed, and a new one soldered back on.
  15. Open the battery cover and lift it up and off of back camera case. Open the battery cover and lift it up and off of back camera case.
    • Open the battery cover and lift it up and off of back camera case.
  16. Locate and unscrew the 2 screws with a #00 Phillips screwdriver. Remove the black seal. Remove the black seal.
    • Locate and unscrew the 2 screws with a #00 Phillips screwdriver.
    • Remove the black seal.
  17. Slide the metal piece off of the battery cover. Slide the metal piece off of the battery cover.
    • Slide the metal piece off of the battery cover.
  18. This is what the battery cover and back case look like completely disassembled.
    • This is what the battery cover and back case look like completely disassembled.
  19. Remove the metal frame from the LCD screen using a spudger. Remove the metal frame from the LCD screen using a spudger. Remove the metal frame from the LCD screen using a spudger.
    • Remove the metal frame from the LCD screen using a spudger.
  20. Pry off the LCD screen from the top using a spudger.  The screen will not be completely free from the device because of a ribbon. Do not pull the screen completely off because it will still be held on by two ribbon cables. Do not pull the screen completely off because it will still be held on by two ribbon cables.
    • Pry off the LCD screen from the top using a spudger. The screen will not be completely free from the device because of a ribbon.
    • Do not pull the screen completely off because it will still be held on by two ribbon cables.
  21. This is what the camera will look like now that the LCD screen is removed.
    • This is what the camera will look like now that the LCD screen is removed.
Rory Aronson
Участник с: 15.04.2010
34 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 6-13, Maness Spring 2010 Member of Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 5
За всё время: 4,428
