Видео обзор
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать OnePlus 8 Pro, воспользуйтесь нашим сервисным руководством.
    Заключительные мысли
    • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
    • Many components are modular and can be individually replaced.
    • Display replacements, which are the most common repairs, are not prioritized in the design.
    • The primary access point for all repairs, the rear panel, is firmly glued in place.
    Уровень ремонтопригодности
    4
    Ремонтопригодность 4из 10
    (10 легче всего ремонтировать)
3 Комментариев
When I was disassembling OP8 Pro in order to replace my display, I did not pay attention there are screws with different sizes . If I use a wrong screw, it can damage new display. Can you help me ? Do you have correct screw sequence point each size?
Claudio Varizo - Ответить
I sure do miss the days when the teardowns/ came with pictures so that I can see the locations of screws and such in between steps. :\
Guess I'll go find something by someone else for help.
Kediil - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 47
За последние 30 дней: 428
За всё время: 26,919
