Инструменты для этого Разбора
Введение
Follow this guide to completely disassemble your Palm IIIc.
This teardown is not a repair guide. To repair your Palm IIIc, use our service manual.
  1. Keep track of all pieces removed from the device.
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Using a spudger, carefully pry open the front and back covers along the side seam.
    • Using a spudger, carefully pry open the front and back covers along the side seam.
    • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
  4. Unhook battery cable from the motherboard and remove the battery.
    • Unhook battery cable from the motherboard and remove the battery.
  5. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Behind the motherboard remove the brown plastic clamp and remove the front screen cover. Behind the motherboard remove the brown plastic clamp and remove the front screen cover.
    • Behind the motherboard remove the brown plastic clamp and remove the front screen cover.
  7. Unhook the blue and red screen cables. Unhook the blue and red screen cables.
    • Unhook the blue and red screen cables.
  8. Pop out the other two brown plastic clamps to release the screen and buttons. Pop out the other two brown plastic clamps to release the screen and buttons. Pop out the other two brown plastic clamps to release the screen and buttons.
    • Pop out the other two brown plastic clamps to release the screen and buttons.
  9. The black clips on the edges of the device (see picture) must be unclipped to remove the motherboard.
    • The black clips on the edges of the device (see picture) must be unclipped to remove the motherboard.
    • Carefully remove the motherboard from the device, pulling the motherboard away from the clips.
  10. Pull the screen out from the front.
    • Pull the screen out from the front.
  11. The object is now fully disassembled.
    • The object is now fully disassembled.
Paulina Trujillo
Участник с: 07.04.2011
241 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 20-69, Walters Spring 2011 Member of Cal Poly, Team 20-69, Walters Spring 2011
CPSU-WALTERS-S11S20G69
5 членов
Автор 8 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 4,598
