Выберете то, что вам нужно
Let's see what's inside!
Turn your Pantech Crux so that the back cover is facing upwards.
Press the indented area at the top of the back cover with one thumb and slide down the cover with your other thumb.
Remove back cover and set it to the side.
Place your thumbnail in the groove at the bottom of the battery.
Lift your thumbnail up to remove the battery from the battery casing.
Grab something with a Phillips #000 Screwdriver head.
Locate the four screws on the corners of where the back cover was.
Use the Phillips #000 Screwdriver to remove these screws.
Locate the two screw covers at the top of the phone.
Grab a 0.8 SIM Eject bit.
Use this bit to get underneath the cover and lift up.
Remove both covers.
Use the Phillips #000 Screwdriver to remove both screws.
Flip your Pantech Crux so the screen is facing upwards.
Locate the sticker above your screen (it has a lock on it).
Use the 0.8 SIM Eject bit to get underneath the sticker.
Peel up the sticker.
Use a Phillips #000 Screwdriver to remove the screw that was beneath the sticker.
Locate the area where the back case meets the silver outlining.
Use your thumb or the 0.8 SIM Eject bit to lift the back case up.
Slide either your thumb or the 0.8 SIM Eject bit between the back case and the silver outlining until the back case comes free.
Lift and remove the back case from the phone.
Place phone with the screen facing downwards.
Locate the buttons on the side of the phone that are now loose.
Remove these buttons by pulling on them with your thumb and pointer finger.
Locate the screw that is in the middle of the motherboard.
Use the Phillips #000 Screwdriver to remove this screw.
Locate the small wire in the bottom right corner of the motherboard.
Release this wire by gently pulling up on it with your thumb and pointer finger.
Lift the motherboard.
Locate the cable that attaches the motherboard to the front case.
Use the 0.8 SIM Eject bit or your nail to lift up and pop off the piece that attaches the cable to the motherboard.
Flip the motherboard to the left of the front case.
Locate the four screws that were below the motherboard.
Use the Phillips #000 Screwdriver to remove all four screws.
Use your thumb or the 0.8 SIM Eject bit to lift up the layer containing the motherboard from the front of the phone.
Run your thumb or the 0.8 SIM Eject bit along the edge of this layer to loosen it.
Remove the layer when it becomes loose enough.
Underneath the layer you just removed is a piece of metal with seven screws on it.
Use a Phillips #000 Screwdriver to remove all seven screws.
Use your finger or the 0.8 SIM Eject bit to remove this metal piece from the front of the phone.
What you see is the back of the screen.
To remove the screen lift it up from the side.
Один комментарий
Thanks for the help. It was fun to take apart my phone and see if I could fix it before trading in for a new one.
The screen is black: it shows light, but it is just projecting a black screen. Since this is a touch screen, that means that I can't see anything that I am doing or even make a phone call. I have memorized where the "answer" button is, so I can receive...
Thanks again!
