Инструменты для этого Разбора
Введение
How to open the device and what you'll find inside.
here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter!
Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;)
there's only one external component connected by cable: the NFC tag
it's easily possible to remove the circuit
lift it on the front side of the device
and pull it this direction - it helps to push at the cinch connector!
when reassembling take care to stick the NFC tag to the correct location in the cover
Один комментарий
Hello. Is there any way to use this device in a car through an adapter or modification?
