Введение
This is a quick teardown of the playstation move controller.
Выберете то, что вам нужно
Once open you will see two ribbon cables.
The one connected to the trigger button is removable.
The ribbon cable attached to light globe is soldered on.
The battery can easily be removed. There is connector on the side of the board.
Battery Specs: Single Cell 1380 mAh 3.7 Volt
Sony Part: LIS1441
Remove the inner plastic (1 Screw) frame to expose the logic board
Remove the 2 top screws and one bottom screw to remove the logic board from the controller.
Logic Board
Chip Closeups Included
503A 04c ALPS - Radio Module
AKM8974948D - MEMS Gyroscope
