Введение
This is my tear down of the Razer Blade 14. I haven't yet seen anyone dismantle this notebook so i decided to give it as try and went as far as I felt comfortable going.
This teardown is not a repair guide. To repair your Razer Blade 14" (2013), use our service manual.
  1. The thin and sleek gaming Notebook from Razer. The thin and sleek gaming Notebook from Razer.
    • The thin and sleek gaming Notebook from Razer.
  2. Remove the 10 Screws holding the back Cover on to reveal the mainboard. DDR3 Ram chips CPU Chipset
    • Remove the 10 Screws holding the back Cover on to reveal the mainboard.
    • DDR3 Ram chips
    • CPU Chipset
    • Liteon 256gb SSD (factory installed)
    • Factory WLAN/BT card
    • Battery
    • Aftermarket MSata SSD (installation screw not included)
  3. Removing the Battery Removing the Battery Removing the Battery
    • Removing the Battery
  4. Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode. Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode. Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode.
    • Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode.
  5. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Removing the Speakers. Removing the Speakers.
    • Removing the Speakers.
  7. The original mSATA SSD. (the secondary seen earlier was added by myself. The original mSATA SSD. (the secondary seen earlier was added by myself. The original mSATA SSD. (the secondary seen earlier was added by myself.
    • The original mSATA SSD. (the secondary seen earlier was added by myself.
  8. Removing the fans. Removing the fans. Removing the fans.
    • Removing the fans.
  9. Removing the heatsinks. Removing the heatsinks. Removing the heatsinks.
    • Removing the heatsinks.
  10. Removing the mainboard. Removing the mainboard. Removing the mainboard.
    • Removing the mainboard.
  11. This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable. This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable. This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable.
    • This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable.
tallme15
Участник с: 09.03.2013
794 Репутация
Автор 2 руководств
Комментариев: 41
Great work, very, very professional ! And thanks, was really curious to see how one looks on the inside !
Darie H - Ответить
Awsome Teardown! Thanks A bunch!
my91331 - Ответить
Thanks a bunch everyone! With all the recognition I've gotten with this teardown I decided I would redo it with pictures taken on a proper DSLR and more of them and more indepth captions for the individual steps, I may even make some replacement guides!
tallme15 - Ответить
Is that a second mSATA slot I see on the left side of the motherboard underneath the large ribbon cable?
Bryce - Ответить
Indeed it is! it functions too, the stock is beneath the cable, the unpopulated is the exposed one, that i had installed an Mushkin atlas in and started using without a hitch.
tallme15 -
Просмотр статистики:
За 24 часа: 7
За 7 дней: 39
За 30 дней: 212
За всё время: 52,822
