Введение
The screws could be torx or Philips head in the body and where the neck bolts to the body.
Выберете то, что вам нужно
Remove all 16 #10-torx screws from the back side of the case.
Gently separate the case pieces.
Unscrew the 2 Philips head screws
Peel off the pads.
Push the colored keys out from the other side.
Unscrew the red screws and pull the board out.
Then, unscrew the blue screws
Pull the bracket things off.
Pull out the pin.
Push from the other side until it comes out.
Take the spring off with the connector
Один комментарий
"unused port" is for a footpedal switch,not positive but believe all GH style guitars have one
