Введение
I've found a vacuum in my utility room. Since I almost never use it, I thought it was a good idea to see how it works... So let's go!!
Выберете то, что вам нужно
The 4.8 Rowenta vacuum can be used for a variety of purposes.
It is charged through its pedestal. The power of the pedestal is:
Input: 230V - 50 Hz - 7W (AC)
Output: 7.5V - 300 mA (DC)
This vacuum has several parts:
The tip
The reservoir which holds the dust and debris
The engine (4.8V)
The pedestal
The power supply
From top to bottom, the reservoir contains 3 parts: the housing, container, and filter.
Remove the two outer Philips #00 screws from the bottom of the engine.
The back of the circuit board will now be visible.
Remove the two inner screws.
Insert a flat screwdriver between the cover and the base of the engine and remove the cover.
The wires of the vacuum are now visible.
The wires connect the charger light, switch,engine, and power wires.
The green box labels the engine.
The orange box labels one of the four batteries (4*1.2V)
The top of the circuit board contains components including capacitors, resistors, wires, and a chip.
The bottom side shows the tracks that connect the components.
Remove the screw securing the handle with a screwdriver.
Open the handle to see the inside using the flat screwdriver.
At the bottom of the pedestal, remove the 4 rubber pieces.
Remove screws using a screwdriver.
Inside the pedestal, the power cable separates into 2 wires. Each wire is connected to a conductive piece.
This completes the vacum cleaner teardown
Один комментарий
This could use some discussion of how to replace the rechargeable batteries used in portable vacuum cleaners.
