Выберете то, что вам нужно
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Samsung Android Phone, воспользуйтесь нашим сервисным руководством.
  1. Samsung AMOLED Display Teardown, Samsung AMOLED Display Teardown: шаг 1, изображение 1 из 2 Samsung AMOLED Display Teardown, Samsung AMOLED Display Teardown: шаг 1, изображение 2 из 2
    • Here it is: The beautiful fortress of pixels known as the Super AMOLED screen.
    • Now, We take to separating it.
  2. Samsung AMOLED Display Teardown: шаг 2, изображение 1 из 1
    • After separating it, we take a closer look at it's insides.
    • The interesting thing is that after we separated it, the screen worked (no black spots or lines) but the touch didn't. This is interesting, because the touch and the pixels are integrated into the same layer. We will try to find out why.
    • It looks like the touch has a separate cable than the screen. This is interesting, because the touch and the pixels are integrated into the same layer, as said above. Note the touch screen controller chip in red.
    • Taking a closer look, it appears that we have cut the touch cable while tediously separating the screen. The adhesive securing the display is no joke.
  3. Samsung AMOLED Display Teardown: шаг 3, изображение 1 из 1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
  4. Samsung AMOLED Display Teardown: шаг 4, изображение 1 из 2 Samsung AMOLED Display Teardown: шаг 4, изображение 2 из 2
    • Using a freezer, we separate the AMOLED display from the glass.
    • We take the screen polarizer film off, and we find out that the screen is really a silver-ish color, not black!
    • However, you technically won't be able to see any text or images on the screen without the black polarizer film.
    • We will update you on our later findings on the inside this screen.
Dinan Blueje
Участник с: 02/04/19
832 Репутация
1 руководство автора
Команда
Everything iPod Участник Everything iPod
Community
62 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 13
За последние 30 дней: 60
За всё время: 4,784
