Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove the three screws.
Pry and remove the panel with an opening pick.
Remove the mainboard with the spudger:
Move on side here for detach the screen
Pull up here for remove the mainboard
Separate the rubber side of the keyboard from the rest of structure
2 Комментариев
I have a samsung GT-E1200I and the port for the charger has died on me. I’ve tried it on several chargers and
there is no signal. I plugged it in and it just went dead. The problem is, I need to get the numbers I had. Is there any way of doing this?
The numbers are maybe stored in the SIM? Have you tried to move the SIM on another phone?
