Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Samsung Galaxy Note5, воспользуйтесь нашим сервисным руководством.
  1. Remove SIM card tray at first. It's Samsung Galaxy Note 5 Duos, so there are two slots. Remove SIM card tray at first. It's Samsung Galaxy Note 5 Duos, so there are two slots. Remove SIM card tray at first. It's Samsung Galaxy Note 5 Duos, so there are two slots.
    • Remove SIM card tray at first. It's Samsung Galaxy Note 5 Duos, so there are two slots.
  2. Remove S pen. Remove S pen. Remove S pen.
    • Remove S pen.
  3. Heat the back cover and cut it sticker underneath. Really strong adhesive. Please be careful with the glass and edged back cover. Heat the back cover and cut it sticker underneath. Really strong adhesive. Please be careful with the glass and edged back cover. Heat the back cover and cut it sticker underneath. Really strong adhesive. Please be careful with the glass and edged back cover.
    • Heat the back cover and cut it sticker underneath. Really strong adhesive. Please be careful with the glass and edged back cover.
  4. Remove the back cover. And the white strip is adhesive sticker.
    • Remove the back cover. And the white strip is adhesive sticker.
  5. Twist off all 20 screws together. Twist off all 20 screws together.
    • Twist off all 20 screws together.
  6. Push the front assembly out from middle housing.  There are a little black adhesive sticker on every corners. Push the front assembly out from middle housing.  There are a little black adhesive sticker on every corners. Push the front assembly out from middle housing.  There are a little black adhesive sticker on every corners.
    • Push the front assembly out from middle housing. There are a little black adhesive sticker on every corners.
  7. Release battery connector from motherboard and pry the battery up. Yes, there is also some adhesive underneath. Release battery connector from motherboard and pry the battery up. Yes, there is also some adhesive underneath. Release battery connector from motherboard and pry the battery up. Yes, there is also some adhesive underneath.
    • Release battery connector from motherboard and pry the battery up. Yes, there is also some adhesive underneath.
  8. Remove two pieces of signal flex cables. And different versions Samsung Galaxy Note 5 may have only one piece signal cable. Remove two pieces of signal flex cables. And different versions Samsung Galaxy Note 5 may have only one piece signal cable.
    • Remove two pieces of signal flex cables. And different versions Samsung Galaxy Note 5 may have only one piece signal cable.
  9. Release LCD connector, digitizer connector, earpiece assembly connector, home button connector on the motherboard. Release LCD connector, digitizer connector, earpiece assembly connector, home button connector on the motherboard.
    • Release LCD connector, digitizer connector, earpiece assembly connector, home button connector on the motherboard.
  10. Release USB board connector on the back and remove the whole motherboard. Release USB board connector on the back and remove the whole motherboard. Release USB board connector on the back and remove the whole motherboard.
    • Release USB board connector on the back and remove the whole motherboard.
  11. Remove the rear camera. There is a black plastic bracket around camera. So we have to remove them together. And there is a little adhesive underlying. Remove the rear camera. There is a black plastic bracket around camera. So we have to remove them together. And there is a little adhesive underlying. Remove the rear camera. There is a black plastic bracket around camera. So we have to remove them together. And there is a little adhesive underlying.
    • Remove the rear camera. There is a black plastic bracket around camera. So we have to remove them together. And there is a little adhesive underlying.
  12. Remove front camera and noise-canceling mic. Remove front camera and noise-canceling mic.
    • Remove front camera and noise-canceling mic.
  13. Remove motor vibrator easily. Remove motor vibrator easily.
    • Remove motor vibrator easily.
  14. Remove earpiece speaker assembly. Remove earpiece speaker assembly. Remove earpiece speaker assembly.
    • Remove earpiece speaker assembly.
  15. That's Samsung Galaxy Note 5 earpiece assembly. It's integrated by speaker and sensors.
    • That's Samsung Galaxy Note 5 earpiece assembly. It's integrated by speaker and sensors.
  16. Now try to separate LCD screen from frame. The difficulty and risk to remove screen alone are getting nearly 5 stars (5 scores all together)respectively. The screen is weak and the adhesive are strong as well too much. Now try to separate LCD screen from frame. The difficulty and risk to remove screen alone are getting nearly 5 stars (5 scores all together)respectively. The screen is weak and the adhesive are strong as well too much.
    • Now try to separate LCD screen from frame. The difficulty and risk to remove screen alone are getting nearly 5 stars (5 scores all together)respectively. The screen is weak and the adhesive are strong as well too much.
  17. Since Samsung applied the design that the USB board come with soft keys together, DIY replace USB board and LCD screen alone become much more difficult. Be careful with the soft sensor keys on the bottom especially the flex.
    • Since Samsung applied the design that the USB board come with soft keys together, DIY replace USB board and LCD screen alone become much more difficult.
    • Be careful with the soft sensor keys on the bottom especially the flex.
    • In fact, the replacement of Samsung Galaxy Note 5 LCD screen, USB board or home button nearly the same with that teardown.
  18. Loosen two soft sensor keys from frame carefully. And remove the last securing screw on USB board. Loosen two soft sensor keys from frame carefully. And remove the last securing screw on USB board.
    • Loosen two soft sensor keys from frame carefully. And remove the last securing screw on USB board.
  19. Remove the USB board finally. Remove the USB board finally.
    • Remove the USB board finally.
  20. Could you see the mark on the right of the home button? Push the button as its direction and can loosen it from securing slot easily. And then cut the adhesive sticker under the flex. Could you see the mark on the right of the home button? Push the button as its direction and can loosen it from securing slot easily. And then cut the adhesive sticker under the flex. Could you see the mark on the right of the home button? Push the button as its direction and can loosen it from securing slot easily. And then cut the adhesive sticker under the flex.
    • Could you see the mark on the right of the home button? Push the button as its direction and can loosen it from securing slot easily. And then cut the adhesive sticker under the flex.
  21. Remove home button flex. Though it's a small component, it's really complicated and difficult to replace, even at the risk to break the screen. Remove home button flex. Though it's a small component, it's really complicated and difficult to replace, even at the risk to break the screen.
    • Remove home button flex. Though it's a small component, it's really complicated and difficult to replace, even at the risk to break the screen.
  22. Done.
    • Done.
Sophia
Участник с: 25.03.2014
43 261 Репутация
Автор 62 руководств
Комментариев: 24
the SIM reader can be changed. the SIM is external or integrated in the motherboard
hammadi - Ответить
Can the s pen be opened too? I wanna know because my s pen clicking mechanism gets stuck and doesn't click.
Alex akerez - Ответить
Yes it separates at the seam where the darker section with the Samsung text meets the light gray part. Here is a decent youtube video some guy made: https://youtu.be/ixNXUh2fnZo I would recommend trying plastic tools to open instead of a razor blade, also graphite is quite messy so I would probably use a small dab of light silicone grease. I buy it at the hardware store in the plumbing section (used for faucet seals). It's a good lightweight grease for rubber & plastic parts and anything sensitive to petroleum base grease. Good luck!
Andrew Kauffman -
Is the memeory stored on the motherboard? Or elsewhere?
ziefern n - Ответить
So did you find out where is the memory stored? My Note 5 dropped in water and circuit on the motherboard is fried. Is there a way i can still recover my data???
parag_oberoi30 -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 51
За последние 30 дней: 331
За всё время: 141,525
