Инструменты для этого Разбора
Введение
This is an unofficial teardown to iFixit of the great Samsung Galaxy S II, enjoy! ;)
The 4.3-inch super Amoled Plus display is simply gorgeous!
Look at how slim the phone is! Only 8.49mm thin!
Back cover is flexible but don't worry it will not break. It also has a nice texture to it.
Look at how compact everything is inside!
Remove the seven visible screws.
Then unclip the back panel starting on the left next to the audio jack. Go slowly.
Removing the back panel gives you an impressive and sophisticated view of the internals.
Removing the motherboard is as simple as it looks !
Unclip the 5 ribbon connectors and the antenna cable.
Then remove the 2 small black screws.
Don't forget to unglue the volume flex and power flex, they are attached to the motherboard. Otherwise the motherboard won't come out easily like it should.
The board with removed EMI shields.
The front.
..and the back.
The front panel without the logic board.
The front facing camera part, the cinch-vibrator-1.mic part and the usb connection-2.mic-antenna board.
The camera connector is at the upper left corner in the second picture.
The power and volume buttons are soldered to the logic board.
This EMI shield is nearly a heat sink.
Should be useful with a 1.2GHz dual core under it!
The front-facing camera and the light sensor are a single part.
The front-facing camera is 2MP, which is better than the iPhone 4's VGA camera.
The vibrator, first mic (did you know there are two?), cinch plug and the earspeaker.
The USB-connection and 2 x mic board.
It's stuck with glue to the front panel.
The (only) antenna cable and a metal shield holding the light sensor in place.
Комментариев: 19
Why not show the great display? =\
Do you see the NFC module ? (the phone come frome England?)
Beacause there is a big disscution between ethier the NFC is not implemented on phone, maybe the chip is on ?
no, it should be from germany, I bought it there ;)
lon -
I'll change it for you ;)
lon -
Where can I purchase any mobile NFC chip and solder on to Galaxy S2 International version (I9100)?
Tai Li -
